- Mute
- Permalink
- Report
I want to make a railing in which, at the base, the top rail curves down to the floor, and the rails in the "body" of the railing meet the top rail. The railing will be hosted by a stair. It would look something like this, where the grey is the rails in the body, the blue is the top rail, and the green is the handrail:
The handrail will be on a separate plane, similar to the near railing shown in this photo:
I have tried editing the top and handrail types, and have edited the paths of the main railing, the top rail and the handrail, and have gotten close; the one part I'm unsure how to do is extend the rails to meet the top rail as the latter turns down to meet the floor. Here is the closest I have gotten, by simply ending the top rail where the End Post is located, shown in the red circle:
I have tried several approaches. If I edit the path of the top rail to try to make it curve down toward the floor, Revit will not make the filleted curve. If I edit the sketch of the main railing to push it up the stair just a few inches, the rails in the main body only reach the end of this sketch and do not reach the edited path of the top rail.
Is there a way to create this curve and have the rails contact the downward-turned top rail?
