Railing Baluster - placement issue
2 REPLIES 2
Ian_H
237 Views, 2 Replies
I created a baluster panel and I can adjust the length of it so that it will better match the length of the railing. The issue is that the panel itself starts past the end of the railing.  How do I fix this?
Labels (3)
2 REPLIES 2
in reply to: Ian_H
Depends on where the origin ref. plane is located in the family.  If it's centered between the right and left edges of the panel, then enter the half width of the panel into the Pattern End's Dist. From Previous cell.
Ian_H
in reply to: barthbradley
Thanks!
Forma Design Contest
