Can anyone help me with this? I tried to place a door and railing but it does not showing properly. I don't know if it is related to my graphic card? Any comments are very appreciated. Thank you in advance.
Could definetly be a graphics card error.
-Switch of hardware acceleration (under Options).
-Try to check your project on another computer.
-Update your drivers and other software (Revit, OS)
Might be due to issues in one or more families, or linked cad file as mentioned by @Karol_Piroska that causes problems for your grpahics card.
You could make make a copy of your project and start removing objects and see if/when the issue disappears to locate the culprit(s).
Louis
Please mention Revit version, especially when uploading Revit files.
3D View crash...rename the view to delete and try opening a new view. If all looks good then get rid of the bad view. If all is still messed up, check your video drivers.
Thank you for your reply, but I did not link/insert and CAD file to this model. If you have face similar issue, how did you manage to resolve it? Im looking forward to hearing from you. Thanks.
Hi, thanks for your reply. I did as your suggestion but it is still the same. But this time it looks like a Venom is eating the building.
