Radial Column Grid
Radial Column Grid
PhilvK
Advisor Advisor
Radial Column Grid
PhilvK
I created the grid arrangement below before adding Level 3 and therefore the grids only appear on plan Levels 1 and 2. Since these grids are not perpendicular to the North, South, East and West elevations, they are not appearing where I can stretch them higher than Level 3 so that they appear on the Level 3 plan. I’ve tried finding something in Properties that controls this but am having no luck. Can anyone guide me please?
RDAOU
@PhilvK
  1. For the concentric grid lines....Place Sections Perpendicular to the Grid lines...then they will show on those sections... Drag up then delete the section once done....
  2. For the Circular/Radial Grid .... Place a section from the Center of the Radial grid to the outside so that it intersects the grid anywhere...The Circular Grid will then show on that section...drag it up and it will show on the new levels
lmpka
I know you already have your answer, but you can also assign your grids to a scope box.  Then you can just adjust the top and bottom of the scope box, and the grids adjust with it.
