Completely new here....they don't come much greener that I am. I am trying to create a radial array where the rays are spaced by length on the curve that they will end on. In the attachment, I need to create an array of the exterior rays that are equally spaced by length of the arc. I will be using the center, heavier arc to provide the spacing.
Can anyone help me with how to do this?
Thank you,
Vi Eckert
Gelöst! Gehe zur Lösung
Hello @Anonymous
First create or select the object you want to array
Here is the sample screencast.
Hello @Anonymous
Since you are using radial array its better to used angle as reference.
