Radeon Pro Confusion
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
3793 Aufrufe, 5 Antworten
I have a question about Radeon Pro graphic cards. If you go to Autodesk Certified Hardware Page, and search for a "Recommended" graphics card for Revit 2018 on Windows 10 64bit, you will get "No results were found. Modifying your selections may return better results" . If you search for "Certified" graphic cards, you get list of AMD Radeon Pro WX cards. However, if you select any of them, it says it is failed in every compatibility category, completely (see attachment). How can this be? This confused me very much. Also, I found this post to be not very promising:
https://forums.autodesk.com/t5/revit-architecture-forum/unkown-graphic-card-radeon-pro-wx-7100/td-p/...
Thank you in advance. Kind regards, Alex
Tags (2)
5 ANTWORTEN 5
Nachricht 2 von 6
dzanta
als Antwort auf: Anonymous
Not sure what's going on with their compatibility site for graphics cards.  This site needs to be revised and updated because it seems to be outdated.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Nachricht 3 von 6
als Antwort auf: dzanta
Thank you @dzanta for a quick respond!
This situation is somewhat weird with compatibility.
If it's ok to ask here, for a small architectural company (10-15p) switching to Revit, is it better to go with professional graphics card, or use gaming cards? I'm really struggling to find clear information about that.
Nachricht 4 von 6
dzanta
after using Revit for 10 years on various computers....
best cards to use are nVidia Quadro 5000 or higher...2GB RAM minimum on graphics card
Xeon processors if you can afford them....otherwise Intel i7 (3.0ghz) or higher
16GB RAM minimum...recommend maxing out RAM on box
SSD drive...no spinning drive (I have a DELL XPS 15 with 512GB PCI M.2 Samsung card...stupid fast)
1920 x 1080 HD display (Revit doesn't like higher resolutions still)
if you have to work and travel and present the Revit model...go with laptop
if you sit on your butt all day...get a workstation (DELL Precision Line)
Gaming cards have issues with displaying Revit model still....but they are wicked nice for gaming! (I have a nVidia GeForce GTX 960M on my XPS)
I have a Quadro 5100m on my work laptop (which is NOT compatible with Revit 2016 or higher)....go figure (but it works well enough)
Nachricht 5 von 6
dzanta
depending on your budget:
$1500 for a decent desktop
$2000 for a decent laptop
$3000 for a serious desktop
$4000 for a serious laptop
17" laptops are big and heavy....good if you are strong...I am not
15" laptops are portable and don't weigh too much for travel
if you get desktops....use a HD monitor (preferrable 30" diagonal or higher)...or multiple monitors....
Nachricht 6 von 6
@dzanta, information you gave is even more than I asked, thank you very much! Have a good day.
Cheers, Alex
