I know that there are 3 choices to print from Current Window, Visible Portion of current window and Selected views/sheets. the closest option is the visible portion...
there is no other way to print visible by 'windowing' around the area needed?
Not in the same way as Autocad....you have to unmaximize your window and adjust the window to what you want to see. Then print "Visible Portion of Current Window".
Keep in mind, depending on your view scale and the paper size you may either get more than what is in the window or less unless you print Scale to fit.
that's what i thought. figured this would have been added to some version.
thank you.
Hi @htews
This will be a great idea for the ideas forum.
I always wanted this feature myself during my BIM Coordination days and frantic printing deadlines.
Please post the idea at your convenience and share the link here.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
there is one already
https://forums.autodesk.com/t5/revit-ideas/print-window/idi-p/6473348
@htews thanks for looking through! ![]()
I added the thread, please feel free to add comments to the ideas post
Viveka
Viveka CD
