"Too many elements missing"
4 ANTWORTEN 4
Nachricht 1 von 5
678 Aufrufe, 4 Antworten
I'm experiencing some problems with an IFC-file that I've opened in Revit 2016. I did it several times without any problems but the latest one just doesn't work.
I get the error message "Too many elements missing, contact Autodesk support". I did found one similar question here on the forum and I tried the solution in that one but I didn't work. The tip I got there was to open the old file, find the missing elements by searching for their ID, and just copy paste them, but I couldn't find them in the old model either. I can't visually see any problems with the model, probably just room separations or something like that.
Anyone have a clue what to do about this? The file was opened in various different softwares with no problems.
4 ANTWORTEN 4
Nachricht 2 von 5
Revit_Whisperer
als Antwort auf: Anonymous
Essentially the file itself is corrupt or it could be a link in the model.
I would try opening the file with audit and detached somewhere that it can't reach the links to test.
If that doesnt' work and you have a working up to date local file that you can make the new central file that will likely be the fastest fix.  If you are on subscription with Autodesk you can log into your subscription account and submit a case to see if they can repair the file.
If you are able to create a new central file then make sure that all users delete or archive your current local model and it's associated backup folder prior to pulling a new local file.
Also all users should be on the same build/update of Revit.
Nachricht 3 von 5
als Antwort auf: Revit_Whisperer
Thank's for the response!
But this is not a central file, so I can't detach it. I get this message if I try to open it up in audit mode.
[cid:image001.jpg@01D240B8.BB5B7920]
And since it's not a central file, I cannot use a local copy either. This is an architectural model made from IFC that I need to link to my model, and usually it works out just fine. And according to them, they haven't changed anything since the last export which worked.
Any other ideas? I'll try anything. :leicht_lächelndes_Gesicht:
Best Regards
Stina Nygren
Structural Engineer
WSP Sverige AB | WSP Descriptor
Direct: +4610-7227840
Mobile: +4676-782 52 61
Office: +4610-722 50 00
Address: Strandgatan 1
SE-831 33 Ostersund
Corporate Identity no: 556057-4880
www.wspgroup.se| Twitter | YouTube | Linkedin| Facebook
CONSULTANCY SERVICES TO THE BUILT AND NATURAL ENVIRONMENT
________________________________
WSP is one of the world's leading engineering professional services consulting firms. We provide services to transform the built environment and restore the natural environment. We have 34,000 employees, based in more than 500 offices, across 40 countries, on every continent.
CONFIDENTIAL
This e-mail is confidential to the named recipient. If you have received a copy in error, please destroy it. You may not use or disclose the contents of this e-mail to anyone, nor take copies of it. The only copies permitted are (1) by the named recipient and (2) for the purposes of completing successful electronic transmission to the named recipient and then only on the condition that these copies, with this notice attached, are kept confidential until destruction.
Nachricht 4 von 5
The picture didn't load, here it is again.
Nachricht 5 von 5
Revit_Whisperer
See if you have a working backup copy that is the best bet...so find one of your modelname.000#.rvt and save that as your new working model.
