"The Problem occurred. The file Could Not Be translated.-1"
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
601 Aufrufe, 2 Antworten
Hi all.
I'm having this problem when sent to rendering the project in the cloud.
Someone already faced this problem? It turned out a way to solve?
The problem started when I installed V-Ray Beta plugin.
Thank you!
2 ANTWORTEN 2
Nachricht 2 von 3
ennujozlagam
als Antwort auf: Anonymous
@Anonymous hello, try to check it HERE. thanks
Nachricht 3 von 3
als Antwort auf: ennujozlagam
Problem solved!!!
If you, like me worked well before, because it stopped working probably because some plugin Revit - in my case V-Ray Beta.
Go to C: \ ProgramData \ Autodesk \ Revit \ Addins \ 2016 and change the extension of installed last * .addin plugin.
The plugin stop working but not uninstalled and you can return to render again !!!
