I was setting up my Revit file to print today, and it just shut down. When I went to re-open my project, it said "The file cannot be opened. There are too many missing elements in it." Its a very important file- is there anyway to get it back?? Thank you!
you can try this: http://help.autodesk.com/view/RVT/2018/ENU/?guid=GUID-9AFAAE6B-4107-4478-8B80-53467FE118DB
Do you have a back up of the file?
DarrenP
H @Anonymous
Its been awhile and I'm checking back to see if there is any progress on this issue?
Let us know if you still seek assistance from the community.
Also, please see article on Many missing elements in Revit 2017 or later model
Looking forward to your reply update.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Try opening with Audit. Check Journal files for the missing elements. Check to see if you have corrupt families - if families are corrupt you will not be able to open with Audit.
Do some housekeeping - clear your local files, clear your %temp% folder, empty Recycle Bin, restart machine.
