Hi everyone, I'm a newbie in Revit. I'm using Revit 2017 student version here. As I know, there's "Shaded with edges" mode in Revit but I can't see it. I attached a picture to show you the problem. I don't know if it just me or something, can you guys help me please? Thank you so much!!!!!
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Shaded mode is default with edges visible. If you want them off (I know you didn't ask for it), then untick the box below:
Hi @Anonymous
I see that you are visiting as a new member. Welcome to the Autodesk community! ![]()
Please click on graphic display options select 'shaded' in the styles drop down and check 'show edges'
You can also go to the
Graphic Display Options
EditPlease select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
