"Serious Issue"
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
3902 Aufrufe, 8 Antworten
"Serious Issue"
Hey guys,
So I have been using Revit 2014 for about 6 months now with our Faro Laser Scanner. We have a project I have been working on for the past 3 or four weeks and have created a close to finished product. Now with the issue. I have put two sets of stairs on this project with little to no issues (save me trying to adjust the slope.) I am attempting to put in a third set on a separate building within the project and I keep getting the error attached to this post. Some help would be much appreciated
8 ANTWORTEN 8
Nachricht 2 von 9
HermanSolomon
als Antwort auf: Anonymous
Hi Muddbugg,
I reckon sharing the journal file just after the crash/es occurs might help us to identify what might make the error occur. you can find the journal files under the following folder location:
C:\Users\<USERNAME>\AppData\Local\Autodesk\Revit\Autodesk Revit <VERSION>\Journals.
Upload it here, adn we will have a look.
http://revitrecess.blogspot.com/
Nachricht 3 von 9
I know this is a lot of info, but I cut it at where I thought it should
be. Let me know if you need the whole journal text file.
'CT [Modify | Stairs]:
' {1} spacer_shr
' {10} Dialog_Essentials_SketchEdit
'Cache:
'E 13-Mar-2017 09:47:08.633; 0:<
Jrn.MouseMove 1 , 85 , 338
Jrn.LButtonUp 0 , 85 , 338
' 0:< getPrioritizedActiveEditMgr() = 00000000082C2200 0000000071FDFE80
0000000000000000
' 0:< Candidates (curIdx = 0): 213525 (-25.901656, +41.886330, +7.500000)
' 0:< ::35:: Delta VM: Avail -52 -> 8383601 MB, Used +47 -> 1582 MB, Peak
+23 -> 1590 MB; RAM: Avail -25 -> 56867 MB, Used +28 -> 1438 MB, Peak +19
-> 1440 MB
' 0.194463 1:<<<;PERF;MISC;drawing
' 0:< ::35:: Delta VM: Avail +83 -> 8383685 MB, Used -84 -> 1499 MB; RAM:
Avail +124 -> 56991 MB, Used -72 -> 1367 MB
'E 13-Mar-2017 09:47:10.368; 0:<
Jrn.MouseMove 0 , 4 , 83
Jrn.PushButton "FormView , Properties , IDD_PROPERTIES_PALETTE" _
, "Edit Type, ID_EDIT_SYMBOL"
'C 13-Mar-2017 09:47:10.369; 0:< ADialog::doModal start
' 0:< ::37:: Delta VM: Avail 8383685 MB, Used +3 -> 1502 MB; RAM: Avail -8
-> 56984 MB, Used +10 -> 1377 MB
' 0:< Unnecessary nesting;SymbolAttribDlg_3;-1;IDS_MODIFY_TYPE_ATTRIB
;N++EB(NB);
'E 13-Mar-2017 09:47:14.881; 0:<
Jrn.Grid "Control; Modal , Type Properties , IDD_SYMBOL_ATTRIB;
IDC_SYMBOL_GRID" _
, "Selection" , ""
'E 13-Mar-2017 09:47:14.944; 0:<
IDC_SYMBOL_GRID" _
, "Button" , "Calculation Rules" , "ValueCol"
' 0:< Unnecessary nesting;ElemGrid_2;-1;IDS_MODIFY_ELEM_ATTRIB ;N++EB(NB);
' 0:< Transaction ElemGRid_3 with ParamDef
'E 13-Mar-2017 09:47:18.312; 0:<
Jrn.PushButton "Modeless , Dialog_StairRamp_StairCalcDlg" _
, "Cancel, IDCANCEL"
' 0:< Unnecessary nesting;ElemGrid_1;-1;IDS_MODIFY_TYPE_ATTRIB ;N++EB(NB);
'E 13-Mar-2017 09:47:22.993; 0:<
Jrn.PushButton "Modal , Type Properties , IDD_SYMBOL_ATTRIB" _
;N++EB(NB);
'C 13-Mar-2017 09:47:23.010; 0:< ADialog::doModal stop
' 0:< ::41:: Delta VM: Avail +11 -> 8383696 MB, Used -9 -> 1493 MB; RAM:
Avail -4 -> 56980 MB, Used +2 -> 1380 MB
'E 13-Mar-2017 09:47:25.175; 0:<
Jrn.MouseMove 0 , 304 , 3
Jrn.RibbonEvent "TabActivated:Architecture"
' 0:< ::43:: Delta VM: Avail -2 -> 8383694 MB, Used +1 -> 1495 MB; RAM:
Avail +28 -> 57008 MB, Used +3 -> 1384 MB
'E 13-Mar-2017 09:47:27.954; 0:<
Jrn.Command "Internal" , "Create a staircase , ID_OBJECTS_STAIRS"
' 0:< Unnecessary nesting;ArrowUI_4;-1;ID_OBJECTS_STAIRS ;N++EB(NB);
' 0:< DBG_WARN: The given value for actualTreadDepth must be greater than
0 and no more than 30000 feet.
'Expect a soft crash after this warning.
'ApplicationException is being thrown on behalf of the function
__cdecl StairsElement::setActualTreadDepth(double)>. Dump file:
C:\Users\tnorris\AppData\Local\Autodesk\Revit\Autodesk Revit
2014\Journals\journal.0067.0001.dmp: line 595 of
n:\build\2014_ship_x64_inst_20130308_1515\source\stairramp\stairrampdb\gensrc\SRC_StairsElement.gen.cpp.
' 2:< ;PERF;MISC;FullUpdateGraphicCacheUpdater::updateAll() DBView3d
id=184267: 329 elements need cache update
' 2:< ;PERF;MISC;FullUpdateGraphicCacheUpdater::updateAll() DBViewPlan
id=29237: 342 elements need cache update
' 2:< ;PERF;MISC;FullUpdateGraphicCacheUpdater::updateAll() DBViewProject
id=3651: 567 elements need cache update
' 2:< <>
'Edit mode: IDR_COMMON
'Command:
'Category: 0
'Bar list:
' Dialog_Revit_DynamicLabelDBar
'Presenter list:
' PP_DebugTab_Binding_Demo
'Product: Revit
'Edit mode context, but no edit mode set.
' 0:< TaskDialog "A serious error has occurred. The current action has
been cancelled. It is strongly recommended that you save your work in a new
file before continuing.
'Would you like to save a recovery file?"
'CommonButtons : Yes, No
'DefaultButton : Yes
Nachricht 4 von 9
Matt__W
Can you post the entire journal file? It contains things such as build version, graphics card, driver number, OS, etc...
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Nachricht 5 von 9
als Antwort auf: Matt__W
' 0:< Initial VM: Avail 8388368 MB, Used 22 MB, Peak 42; RAM: Avail 58275 MB, Used 43 MB, Peak 42
'C 13-Mar-2017 09:46:26.949; 0:< started recording journal file
' Build: 20130308_1515(x64)
Dim Jrn
Set Jrn = CrsJournalScript
' 0:< ->desktop InitApplication
' 0:< <-desktop InitApplication
' 0:< ->desktop InitNativeInstance
' 0:< Options::loadOptions: m_strDataLibraryLocations=Imperial Library=C:\ProgramData\Autodesk\RVT 2014\Libraries\US Imperial\,Imperial Detail Library=C:\ProgramData\Autodesk\RVT 2014\Libraries\US Imperial\Detail Items (defaultLib==\Library)
' 0:< ::0:: Delta VM: Avail -56 -> 8388312 MB, Used +10 -> 33 MB; RAM: Avail -20 -> 58255 MB, Used +20 -> 63 MB, Peak +20 -> 63 MB
'C 13-Mar-2017 09:46:27.093; 0:< License initialization complete
' 0:< ::0:: Delta VM: Avail -915 -> 8387398 MB, Used +193 -> 227 MB, Peak +184 -> 227 MB; RAM: Avail -202 -> 58054 MB, Used +210 -> 274 MB, Peak +210 -> 274 MB
' 0:< Autodesk Revit 2014
' 0:< 64-bit load point = C:\Program Files\Autodesk\Revit 2014
' 0:< this journal = C:\Users\tnorris\AppData\Local\Autodesk\Revit\Autodesk Revit 2014\Journals\journal.0067.txt
' 0:< ::0:: Delta VM: Avail -54 -> 8387344 MB, Used +8 -> 235 MB, Peak +40 -> 267 MB; RAM: Avail -16 -> 58038 MB, Used +13 -> 287 MB, Peak +17 -> 291 MB
' 0:< Journal Init
' 0:< Log Summary
' 0:< .Count
' 0:< ...CloseHiddenWindowsInAllDocuments = 1
' 0:< ...onUpdateWindowCloseHidden = 1
' 0:< ...ProjectRecsCreated = 1
' 0:< .ThreadPool
' 0:< ...ActivePoolSize = 21
' 0:< ...ConfiguredPoolSize = automatic
' 0:< ...ParallelCores = 12
' 0:< ...RequestedPoolSize = automatic
' 0:< .Tuning
' 0:< ...ElemTable = 1 (Serial except when multithreaded)
' 0:< ...Global = 0 (Scalable)
' 0:< ...PoolGlobal = 1 (Pool)
' 0:< ...PoolLocking = 1 (Locking)
' 0:< ...PoolScalable = 1 (Pool)
' 0:< ...PoolTreeNodes = 0 (Allocator)
' 0:< ...Scalable = 0 (Scalable)
'H 13-Mar-2017 09:46:30.739; 0:<
Jrn.Data "JournalDefaultTemplate" _
, "Construction Template=$AllUsersAppData\Templates\US Imperial\Construction-Default.rte, Architectural Template=$AllUsersAppData\Templates\US Imperial\default.rte, Structural Template=$AllUsersAppData\Templates\US Imperial\Structural Analysis-Default.rte, Mechanical Template=$AllUsersAppData\Templates\US Imperial\Mechanical-Default.rte"
Jrn.Data "JournalDefaultViewDiscipline" _
, "Coordination"
Jrn.Directive "Version" _
, "2014.000", "2.143"
Jrn.Directive "Username" _
, "tnorris"
Jrn.Directive "CategoryDisciplineFilter" _
, -1
Jrn.Directive "DisciplineOption" _
, 7677
Jrn.Directive "TabDisplayOptions" _
, "StayOnModifyInProject", 0
, "StayOnModifyInFamily", 1
, "ActiveCtOnSelection", 1
Jrn.Directive "AllowLinkSelection" _
, 1
Jrn.Directive "AllowFaceSelection" _
, 1
Jrn.Directive "AllowUnderlaySelection" _
, 1
Jrn.Directive "AllowPinnedSelection" _
, 0
' 0:< ::0:: Delta VM: Avail -12 -> 8387333 MB, Used 235 MB; RAM: Avail -17 -> 58021 MB, Used +1 -> 288 MB, Peak +4 -> 296 MB
' 0:< API_SUCCESS { Registered an external service.: ServiceId(a9bdf0fd-2632-429e-bc35-50ebc2b824d2); VendorId(ADSK); Description(Navisworks Export Service) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(de6db8de-dea6-40bd-9503-4ffe62ff6143); VendorId(ADSK); Description(The external service to view and modify code checking parameter in analytical elements.) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(d8b95737-f943-414c-9ad7-86785bf1acbc); VendorId(ADSK); Description(IFC) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(d8b95737-f943-414c-9ad7-86785bf1acbc); ServerId(ef8d0493-7f36-42b5-b9aa-8aaac716482b); Name(Default IFC); VendorId(ADSK); Description(Default IFC) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(98d317e2-e943-4cc0-a3da-2edf32a5d942); VendorId(ADSK); Description(IFC) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(98d317e2-e943-4cc0-a3da-2edf32a5d942); ServerId(660a7370-f6d6-43c8-8456-6b2eea785110); Name(Default IFC); VendorId(ADSK); Description(Default IFC) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540); VendorId(ADSK); Description(Duct fitting and accessory pressure drop service) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780); VendorId(ADSK); Description(Pipe fitting and accessory pressure drop service) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0); VendorId(ADSK); Description(Duct Straight Segment Pressure Drop Calculation) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3); VendorId(ADSK); Description(Pipe Straight Segment Pressure Drop Calculation) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(bf0da776-5307-4747-8285-f358e92a90d0); VendorId(ADSK); Description(Convert Fixture Units to Flow for Plumbing Fixtures, which is applicable to Domestic Water System Flow Calculation) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(52009bda-c817-4aef-aa31-36dc3742516e); VendorId(ADSK); Description(Duct fitting and accessory pressure drop UI service) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af); VendorId(ADSK); Description(Pipe fitting and accessory pressure drop UI service) }
' 0:< ::0:: Delta VM: Avail -75 -> 8387258 MB, Used +22 -> 258 MB; RAM: Avail -22 -> 58000 MB, Used +29 -> 317 MB, Peak +22 -> 318 MB
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(bf0da776-5307-4747-8285-f358e92a90d0); ServerId(56121d7d-e1d7-42a3-bed8-f4d1d32058c8); Name(Plumbing Fixture Flow); VendorId(ADSK); Description(Calculation of flow using the Plumbing Fixture Flow method.) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3); ServerId(ea275fb1-5d7b-47d6-b828-bf856df9bfd5); Name(Pipe Pressure Drop); VendorId(ADSK); Description(Calculation of pressure drop using Darcy-Weisbach method.) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0); ServerId(042a10e0-8d24-46a4-9596-d192b3125d0c); Name(Duct Pressure Drop); VendorId(ADSK); Description(Calculation of duct pressure drop using Darcy method.) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540); ServerId(76eff5da-2e71-45f7-b940-cc5716328ba0); Name(Not Defined); VendorId(ADSK); Description(The Pressure Drop on the fitting will be treated as 0.) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540); ServerId(8baf7d75-8b9b-46d0-b8ce-3ad1c19e6b19); Name(Coefficient from ASHRAE Table); VendorId(ADSK); Description(Version 5.0.0 of the ASHRAE duct fitting database has been implemented for duct fittings. When using this calculation method, the duct fitting coefficient will be read from the mapped ASHRAE table.) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540); ServerId(5a598293-1504-46cc-a9c0-de55c82848b9); Name(Specific Coefficient); VendorId(ADSK); Description(Customize the Loss Coefficient on the fitting, then using the following method to calculate duct fitting pressure drop. this method only available for two connector fittings, like elbow, transitions, etc.) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540); ServerId(46245996-eebb-4536-ac17-9c1cd917d8cf); Name(Specific Loss); VendorId(ADSK); Description(Customize the Pressure Drop on the fitting, this method only available for two connector fittings, like elbow, transitions, etc.) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780); ServerId(61e7b8e1-16d1-4fe4-82f0-327af736323f); Name(Not Defined); VendorId(ADSK); Description(The Pressure Drop on the fitting will be treated as 0.) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780); ServerId(51dd5e98-a9dd-464b-b286-4a37953610bf); Name(K Coefficient from Table); VendorId(ADSK); Description(CIBSE/ASHRAE/Crane standards are used for pipe fitting loss definition based on the pipe fitting types.) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780); ServerId(32d58662-b467-4f7b-b728-f6ad7b7ba5e3); Name(Specific Coefficient); VendorId(ADSK); Description(Customize the Loss Coefficient on the fitting, then using the following method to calculate pipe fitting pressure drop. This method only available for two connector fittings, like elbow, transitions, etc.) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780); ServerId(16f4f7be-0ac0-461d-a9a4-1d3511cd280e); Name(Specific Loss); VendorId(ADSK); Description(Customize the Pressure Drop on the fitting, this method only available for two connector fittings, like elbow, transitions, etc.) }
' 0:< Added new API external application RaaS, class Autodesk.RaaS.RevitAddin.EApplication, assembly RaaSApplication.dll, vendorId ADSK, vendor description Autodesk, www.autodesk.com.
' 0:< API registering ApplicationClosing event by application RaaS (d4f6554b-5d68-4a13-beec-4a0647c34408).
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_IN_CLOUD' Executed implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2014\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application RaaS (d4f6554b-5d68-4a13-beec-4a0647c34408). }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_IN_CLOUD' CanExecute implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2014\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application RaaS (d4f6554b-5d68-4a13-beec-4a0647c34408). }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_GALLERY' Executed implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2014\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_GALLERY' CanExecute implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2014\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< Added new API external application AutoLoad, class AutoLoader.AutoLoader, assembly AutoLoader.dll, vendorId ADSK, vendor description .
'H 13-Mar-2017 09:46:31.555; 0:<
Jrn.Directive "IdleTimeTaskSymbol" _
, "0.ExternalEvent"
' 0:< Added new API external application FittingAndAccessoryCalculationUIServers, class FittingAndAccessoryCalculationUIServers.ServerApp, assembly FittingAndAccessoryCalculationUIServers.dll, vendorId ADSK, vendor description Autodesk, www.autodesk.com.
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(52009bda-c817-4aef-aa31-36dc3742516e); ServerId(607992d7-359d-4593-b497-8aa238e2c564); Name(Duct not defined pressure drop UI server); VendorId(ADSK); Description(Duct not defined pressure drop UI server) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(52009bda-c817-4aef-aa31-36dc3742516e); ServerId(9641a039-441e-42e2-93a6-c0e2177cc23c); Name(Duct specific coefficient pressure drop UI server); VendorId(ADSK); Description(Duct specific coefficient pressure drop UI server) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(52009bda-c817-4aef-aa31-36dc3742516e); ServerId(d3b5e81d-9b8c-40da-8efb-99dd37fda611); Name(Duct specific loss pressure drop UI server); VendorId(ADSK); Description(Duct specific loss pressure drop UI server) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(52009bda-c817-4aef-aa31-36dc3742516e); ServerId(25fa8de2-67c4-47d1-91f6-bd6f0803a5ed); Name(Duct coefficient from table pressure drop UI server); VendorId(ADSK); Description(Duct coefficient from table pressure drop UI server) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af); ServerId(62917391-e14d-4897-ad0c-05342d71e4f9); Name(Pipe not defined pressure drop UI server); VendorId(ADSK); Description(Pipe not defined pressure drop UI server) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af); ServerId(247265b6-7b71-4147-97c6-cc52b39c12aa); Name(Pipe specific coefficient pressure drop UI server); VendorId(ADSK); Description(Pipe specific coefficient pressure drop UI server) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af); ServerId(5978b92a-3f0b-4691-bbc8-caf2fae20a71); Name(Pipe specific loss pressure drop UI server); VendorId(ADSK); Description(Pipe specific loss pressure drop UI server) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af); ServerId(cda19b6f-fbd5-4725-a0ce-f159bf5d02fe); Name(Pipe K coefficient from table pressure drop UI server); VendorId(ADSK); Description(Pipe K coefficient from table pressure drop UI server) }
' 0:< Added new API external application PressureLossReport, class PressureLossReport.PressureLossReportApplication, assembly PressureLossReport.dll, vendorId ADSK, vendor description Autodesk, www.autodesk.com.
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_DUCT_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2014\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Duct Pressure Loss Report CanExecute event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_DUCT_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2014\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Duct Pressure Loss Report Executed event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_PIPE_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2014\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Pipe Pressure Loss Report CanExecute event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_PIPE_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2014\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Pipe Pressure Loss Report Executed event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_DUCT_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2014\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_DUCT_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2014\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_PIPE_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2014\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_PIPE_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2014\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< ::0:: Delta VM: Avail -8 -> 8387251 MB, Used +6 -> 265 MB, Peak +4 -> 271 MB; RAM: Avail -2 -> 57999 MB, Used +8 -> 326 MB, Peak +11 -> 330 MB
'C 13-Mar-2017 09:46:31.803; 0:< ->processShellCommand
'E 13-Mar-2017 09:46:31.803; 0:<
Jrn.Command "Internal" , "Show or hide recent files , ID_STARTUP_PAGE"
' 0:< ::1:: Delta VM: Avail -18 -> 8387233 MB, Used 265 MB; RAM: Avail 57999 MB, Used +2 -> 329 MB
'C 13-Mar-2017 09:46:31.879; 0:< <-processShellCommand
' 0:< ->DesktopMFCApp::doStartupWarnings
'C 13-Mar-2017 09:46:31.879; 0:< manage licensing
' 0:< ::1:: Delta VM: Avail 8387233 MB, Used +0 -> 266 MB; RAM: Avail +30 -> 58029 MB, Used +2 -> 331 MB, Peak +1 -> 331 MB
' 0:< License mode: Standalone
' 0:< Status: Your license is non-expiring.
' 0:< Type: Standalone - Locked
' 0:< Usage: Commercial
' 0:< Behavior: Permanent
' 0:< Expiration: None
'C 13-Mar-2017 09:46:32.593; 0:< manage involvement
'C 13-Mar-2017 09:46:32.594; 0:< manage debug modes
'C 13-Mar-2017 09:46:32.594; 0:< MFCApp::testGraphicsHardware
' 0:< ::1:: Delta VM: Avail -38 -> 8387196 MB, Used +2 -> 268 MB; RAM: Avail +0 -> 58030 MB, Used +5 -> 337 MB, Peak +5 -> 337 MB
' 0:< Revit Graphics Information
' 0:< Current Mode : DirectX Hardware
' 0:< Use Hardware: ON
' 0:< Use Overlays : ON
' 0:< useNullDevice=false
' 0:< START CanUseHardware(forced)
' 1:< ::1:: Delta VM: Avail -78 -> 8387118 MB, Used +69 -> 337 MB, Peak +70 -> 341 MB; RAM: Avail -22 -> 58008 MB, Used +27 -> 364 MB, Peak +29 -> 366 MB
' 1:< DX Device: DirectX 11, Hardware
'C 13-Mar-2017 09:46:33.335; 1:< START video card certification
' 1:< ::1:: Delta VM: Avail -2127 -> 8384991 MB, Used +14 -> 352 MB, Peak +10 -> 352 MB; RAM: Avail -21 -> 57988 MB, Used +20 -> 385 MB, Peak +18 -> 385 MB
' 1:<
'Current driver version: 21.21.13.7878
'Certified driver(s):
' 1:< VIDEO CARD ENVIRONMENT: CARD="NVIDIA GeForce GTX 980 Ti" ManufacturerID="10DE" DeviceID="17C8" osID="2000" DRIVER="21.21.13.7878" DEVICE="DX11" FL_Caps="50" (Shader Model)
'C 13-Mar-2017 09:46:33.566; 1:< FINISH video card certification
' 0.861067 1:<<CanUseHardware(forced)
' 0:<
'Can use hardware=y
'Hardware support flags:
'FeatureLevelLow=n
'DrvOlderThanTested=n
'DrvNewerThanTested=n
'CardIsNotListed=y
'NotCertifiedEnv=n
'3GBSwitchIsOn=n
'SoftwareModeForced=n
' 0:< FINISH CanUseHardware(forced)
'C 13-Mar-2017 09:46:33.566; 0:< postConditionalWarnings
'C 13-Mar-2017 09:46:33.566; 0:< giveAtomRegistrationWarnings
'C 13-Mar-2017 09:46:33.566; 0:< warnings->consumeAll
'C 13-Mar-2017 09:46:33.566; 0:< Process result of DebugModes-Changed Task Dialog
'C 13-Mar-2017 09:46:33.566; 0:< isMaterialLibraryAvailable
'C 13-Mar-2017 09:46:33.567; 0:< start up warnings for AddIns
' 0:< <-DesktopMFCApp::doStartupWarnings
' 0:< <-desktop InitNativeInstance
' 0:< ->desktop InitManagedInstance
' 0:< <-desktop InitManagedInstance
' 0:< ::1:: Delta VM: Avail -71 -> 8384921 MB, Used +17 -> 369 MB, Peak +17 -> 369 MB; RAM: Avail -26 -> 57962 MB, Used +24 -> 409 MB, Peak +24 -> 409 MB
'C 13-Mar-2017 09:46:33.754; 0:< appPriv idle
' 0:< OPERATING SYSTEM INFORMATION:
' 0:< BuildNumber : 7601
' 0:< BuildType : Multiprocessor Free
' 0:< Caption : Microsoft Windows 7 Professional
' 0:< CodeSet : 1252
' 0:< CountryCode : 1
' 0:< CSDVersion : Service Pack 1
' 0:< FreePhysicalMemory : 59348908
' 0:< FreeSpaceInPagingFiles : 4194304
' 0:< FreeVirtualMemory : 63352848
' 0:< MaxProcessMemorySize : 8589934464
' 0:< OSLanguage : 1033
' 0:< OSType : 18
' 0:< ServicePackMajorVersion : 1
' 0:< ServicePackMinorVersion : 0
' 0:< TotalVirtualMemorySize : 71222348
' 0:< TotalVisibleMemorySize : 67029904
' 0:< Version : 6.1.7601
' 0:< Process affinity mask : FFF
' 0:< System affinity mask : FFF
' 0:< PROCESSOR INFORMATION:
' 0:< AddressWidth : 64
' 0:< Architecture : 9
' 0:< Availability : 3
' 0:< Caption : Intel64 Family 6 Model 63 Stepping 2
' 0:< CurrentClockSpeed : 3301
' 0:< DataWidth : 64
' 0:< Description : Intel64 Family 6 Model 63 Stepping 2
' 0:< Family : 179
' 0:< L2CacheSize : 1536
' 0:< Level : 6
' 0:< Manufacturer : GenuineIntel
' 0:< MaxClockSpeed : 3301
' 0:< Name : Intel(R) Core(TM) i7-5820K CPU @ 3.30GHz
' 0:< ProcessorType : 3
' 0:< Revision : 16130
' 0:< Role : CPU
' 0:< SocketDesignation : CPUSocket
' 0:< StatusInfo : 3
' 0:< Version :
' 0:< VIDEO CONTROLLER INFORMATION:
' 0:< AdapterCompatibility : NVIDIA
' 0:< AdapterDACType : Integrated RAMDAC
' 0:< AdapterRAM : -1048576
' 0:< Caption : NVIDIA GeForce GTX 980 Ti
' 0:< CurrentBitsPerPixel : 32
' 0:< CurrentHorizontalResolution : 1920
' 0:< CurrentNumberOfColors : 4294967296
' 0:< CurrentRefreshRate : 60
' 0:< CurrentVerticalResolution : 1080
' 0:< Description : NVIDIA GeForce GTX 980 Ti
' 0:< DriverDate : 20170223000000.000000-000
' 0:< DriverVersion : 21.21.13.7878
' 0:< MaxRefreshRate : 60
' 0:< MinRefreshRate : 50
' 0:< Monochrome : 0
' 0:< Name : NVIDIA GeForce GTX 980 Ti
' 0:< VideoArchitecture : 5
' 0:< VideoMemoryType : 2
' 0:< VideoModeDescription : 1920 x 1080 x 4294967296 colors
' 0:< VideoProcessor : GeForce GTX 980 Ti
' 0:< PRINTER INFORMATION:
' 0:< Caption : Send To OneNote 2016
' 0:< Default : 0
' 0:< DeviceID : Send To OneNote 2016
' 0:< Direct : 0
' 0:< DriverName : Send to Microsoft OneNote 16 Driver
' 0:< EnableBIDI : 0
' 0:< EnableDevQueryPrint : 0
' 0:< HorizontalResolution : 600
' 0:< Local : -1
' 0:< Name : Send To OneNote 2016
' 0:< Network : 0
' 0:< PortName : nul:
' 0:< PrintJobDataType : RAW
' 0:< PrintProcessor : winprint
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< SpoolEnabled : -1
' 0:< VerticalResolution : 600
' 0:< Caption : Microsoft XPS Document Writer
' 0:< Default : 0
' 0:< DeviceID : Microsoft XPS Document Writer
' 0:< Direct : 0
' 0:< DriverName : Microsoft XPS Document Writer
' 0:< Local : -1
' 0:< Name : Microsoft XPS Document Writer
' 0:< Network : 0
' 0:< PortName : XPSPort:
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< Caption : HP Color LaserJet CP5220 Series PCL6
' 0:< Default : 0
' 0:< DeviceID : HP Color LaserJet CP5220 Series PCL6
' 0:< Direct : 0
' 0:< DriverName : HP Color LaserJet CP5220 Series PCL6
' 0:< Local : -1
' 0:< Name : HP Color LaserJet CP5220 Series PCL6
' 0:< Network : 0
' 0:< PortName : 192.168.1.121
' 0:< PrintProcessor : hpzppwn7
' 0:< RawOnly : 0
' 0:< Shared : -1
' 0:< Caption : Fax
' 0:< Default : 0
' 0:< DeviceID : Fax
' 0:< Direct : 0
' 0:< DriverName : Microsoft Shared Fax Driver
' 0:< HorizontalResolution : 200
' 0:< Local : -1
' 0:< Name : Fax
' 0:< Network : 0
' 0:< PortName : SHRFAX:
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< VerticalResolution : 200
' 0:< Caption : \\2012SERVER\Canon Plotter
' 0:< Default : 0
' 0:< DeviceID : \\2012SERVER\Canon Plotter
' 0:< Direct : 0
' 0:< DriverName : Canon iPF765
' 0:< EnableBIDI : -1
' 0:< Local : 0
' 0:< Name : \\2012SERVER\Canon Plotter
' 0:< Network : -1
' 0:< PortName : IP_192.168.1.205
' 0:< PrintProcessor : Canon iPF765 Print Processor
' 0:< RawOnly : 0
' 0:< Shared : -1
' 0:< Caption : \\2012SERVER\Xerox WorkCentre 7500 Series Class Driver
' 0:< Default : -1
' 0:< DeviceID : \\2012SERVER\Xerox WorkCentre 7500 Series Class Driver
' 0:< Direct : 0
' 0:< DriverName : Microsoft enhanced Point and Print compatibility driver
' 0:< Local : 0
' 0:< Name : \\2012SERVER\Xerox WorkCentre 7500 Series Class Driver
' 0:< Network : -1
' 0:< PortName : 192.168.1.100
' 0:< RawOnly : 0
' 0:< Shared : -1
' 0:< PRINTER CONFIGURATION INFORMATION:
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : Send To OneNote 2016
' 0:< DriverVersion : 1539
' 0:< Orientation : 1
' 0:< PaperLength : 2794
' 0:< PaperSize : Letter 8 1/2 x 11 in
' 0:< PaperWidth : 2159
' 0:< PrintQuality : 600
' 0:< SpecificationVersion : 1025
' 0:< XResolution : 600
' 0:< YResolution : 600
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : Microsoft XPS Document Writer
' 0:< Duplex : 0
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : HP Color LaserJet CP5220 Series PCL6
' 0:< Duplex : 0
' 0:< MediaType : 277
' 0:< Color : 1
' 0:< Description : Fax
' 0:< DriverVersion : 1024
' 0:< Duplex : 0
' 0:< PrintQuality : 200
' 0:< XResolution : 200
' 0:< YResolution : 200
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : \\2012SERVER\Canon Plotter
' 0:< DriverVersion : 1076
' 0:< Orientation : 2
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : \\2012SERVER\Xerox WorkCentre 7500 Series Class Driver
' 0:< Duplex : 0
' 0:< MediaType : 265
'E 13-Mar-2017 09:46:38.336; 0:<
Jrn.Command "StartupPage" , "Open this project , ID_FILE_MRU_FILE2"
'H 13-Mar-2017 09:46:38.338; 0:<
Jrn.Data "MRUFileName" _
, "E:\DH_City_Hall\Scene Exports and Revit Data\Denham Springs City Hall(Recovery).rvt"
' 1:< ::2:: Delta VM: Avail -16 -> 8384906 MB, Used +1 -> 370 MB, Peak +1 -> 371 MB; RAM: Avail -8 -> 57955 MB, Used +4 -> 413 MB, Peak +4 -> 414 MB
' 1:< System (MB) [Available / Total ] [Revit Memory Usage (MB) ]
' 1:< RAM Statistics: 57955 / 65458 413=InUse 414=Peak
' 1:< VM Statistics: 8384906 / 8388607 370=InUse 371=Peak
'C 13-Mar-2017 09:46:38.348; 2:< File: Open
' 3:< DataStorageInterface created 0x0000000011A7F9D0
' 3:< Connecting session [$5ce08033] to Worksharing Log [C:\Users\tnorris\AppData\Local\Autodesk\Revit\Autodesk Revit 2014\Journals\journal.0067.txt]
' 0.000207 4:<<<WorksharingLog::getSlog []
' 3:< Additional IP address/name found for host TNorris-PC: 192.168.1.105
' 4:< MasterLocks 0x00000000450AC090 ensureAppropriateStorage DataStorageInterface WAS m_oDataStorage 0x0000000011A7F9D0 m_pDataStorage 0x0000000011A7F9D0
' 4:< DataStorageInterface created 0x0000000011A88050
' 4:< DataStorageInterface destroyed 0x0000000011A7F9D0
' 4:< MasterLocks 0x00000000450AC090 ensureAppropriateStorage DataStorageInterface m_oDataStorage 0x0000000011A88050 m_pDataStorage 0x0000000011A88050
' 4:< ::2:: Delta VM: Avail -16 -> 8384891 MB, Used 370 MB; RAM: Avail 57955 MB, Used +0 -> 414 MB
' 4:< MasterLocks 0x00000000450AC090 DummyStorage stole m_oDataStorage 0x0000000011A88050 but left m_pDataStorage 0x0000000011A88050
' 4:< LPSTORAGE ACQUIRED: DocumentStorage=0x11a52a30, plpRootStg=0x11a52af8, lpRootStg=0x11b3b9a0
' 0.001270 4:<<acquireFileLock
' 0.003242 3:<<OpenDocumentTask::acquireFileLock
' 0.069263 6:<<<DictionaryAnalysis::initialize
' 0.012821 6:<<<loadAllClasses
' 0.002076 6:<<<RegisterPreDocLoadCallback::invokeCallbacks
' 0.000508 7:<<<LoadModel DSI
' 0.000634 6:<<loading DocumentStorageIndex
'E 13-Mar-2017 09:46:38.440; 6:<
' [Jrn.BasicFileInfo] Rvt.Attr.Worksharing: Not enabled Rvt.Attr.UserName: Rvt.Attr.CentralModelPath: Rvt.Attr.RevitBuildVersion: Autodesk Revit 2014 (Build: 20130308_1515(x64)) Rvt.Attr.LastSavePath: E:\DH_City_Hall\Scene Exports and Revit Data\Denham Springs City Hall(Recovery).rvt Rvt.Attr.ProjectSpark: notProjectSpark Rvt.Attr.LocaleWhenSaved: ENU
' 7:< [ISL] On open, Adler Checksum: 0x81c23fc4 [E:\DH_City_Hall\Scene Exports and Revit Data\Denham Springs City Hall(Recovery).rvt]
' 0.017320 7:<<<Checking Checksum
' 6:< [ISL] Read last modification time: 09-Mar-2017 15:58:09 (UTC: 09-Mar-2017 21:58:09)
' 0.012014 7:<<<app infos and other global data
' 6:< File was saved in Autodesk Revit 2014 (Build: 20130308_1515(x64))
' 7:< ::3:: Delta VM: Avail -16 -> 8384875 MB, Used +16 -> 386 MB, Peak +15 -> 386 MB; RAM: Avail -14 -> 57941 MB, Used +13 -> 427 MB, Peak +13 -> 427 MB
' 0.000313 8:<<<ET::repairModificationDatesOutOfSequence
' 7:< Loaded ElemTable: Size=37612
' 0.032424 7:<<ElemTable
' 0.000066 7:<<<ContentDocuments
' 0.002472 7:<<<History
' 0.000147 7:<<<increment table
' 0.000300 7:<<<WorksetTable
' 0.000008 7:<<<partitionStorageLock.open
' 0.000367 8:<<<loadLatestVersionsEstimate
' 8:< Loaded elemStream#56: uncompSize=12, compSize=236, count=0
' 8:< ::3:: Delta VM: Avail -106 -> 8384769 MB, Used +33 -> 420 MB, Peak +33 -> 420 MB; RAM: Avail -80 -> 57862 MB, Used +50 -> 478 MB, Peak +50 -> 478 MB
' 8:< Loaded elemStream#54: uncompSize=46178464, compSize=7251555, count=37612
' 0.095432 8:<<<loadLatestVersion
' 0.004901 9:<<<ElementReceiver::commitSwapouts()
' 0.004936 8:<<els.commit
' 0.100823 7:<<loadSelectedPartitions
' 0.167325 6:<<DocumentStorageIndexImpl::loadDocument()
' 7:< Current project ADocument version:2659
' 8:< ::3:: Delta VM: Avail 8384769 MB, Used +0 -> 421 MB, Peak +2 -> 422 MB; RAM: Avail -15 -> 57847 MB, Used +3 -> 481 MB, Peak +4 -> 482 MB
' 0.143141 9:<<<updating dependencies in delayed deletion
' 0.000976 9:<<<getAllNonexistentParents in delayed deletion
' 0.015002 9:<<<findAppInfoNonexistentParents in delayed deletion
' 0.159281 8:<<delayed deletion
' 0.001724 8:<<<forceResetOfElemRecOwnerCache
' 0.185621 7:<<ADocumentUpgrade::docUpgrade
' 0.442380 4:<<LoadSerialize
' 0.442765 3:<<LoadFromStorage
' 0.003281 4:<<<forceResetOfElemRecOwnerCache
' 4:< Unnecessary nesting;Document\PostLoadDocument.cpp;160;String_Revit_DelayedPropagatoinRegen ;N++E(N);
' 5:< System (MB) [Available / Total ] [Revit Memory Usage (MB) ]
' 5:< RAM Statistics: 57846 / 65458 482=InUse 482=Peak
' 5:< VM Statistics: 8384769 / 8388607 421=InUse 422=Peak
' 5:< 000000001031A210 CompactMemoryManager Memory Statistics: 8 MB with 4 MB view
' 5:< 000000001031A288 CompactMemoryManager Memory Statistics: 8 MB with 4 MB view
' 5:< 000000001031A328 CompactMemoryManager Memory Statistics: 8 MB with 4 MB view
' 5:< 000000001031A260 CompactMemoryManager Memory Statistics: 8 MB with 4 MB view
' 5:< 000000001031A2D8 CompactMemoryManager Memory Statistics: 8 MB with 4 MB view
' 5:< 000000001031A238 CompactMemoryManager Memory Statistics: 8 MB with 4 MB view
' 5:< 000000001031A300 CompactMemoryManager Memory Statistics: 4 MB with 4 MB view
' 5:< 000000001031A2B0 CompactMemoryManager Memory Statistics: 2 MB with 2 MB view
' 5:< Element Expansion Statistics:
' 5:< 0% Opening Plans (0)
' 5:< 0% Opening RC Plans (0)
' 5:< 0% Opening 3d Views (0)
' 5:< 0% Opening Elevations and Sections (0)
' 5:< 0% In Regnerate (0)
' 5:< 0% In Autojoin (0)
' 5:< 0% In Overlap Checking (0)
' 5:< 0% Reviewing PostedWarnings (0)
' 5:< 100% Other (1234643)
' 5:< total bytes expanded: 1234643
' 5:< ;EES;0;0;0;0;0;0;0;0;100;
' 0.000006 6:<<<ppg constructor
' 0.000005 6:<<<updating dependencies in dp
' 0.000001 7:<<<updating dependencies in delayed deletion
' 0.001047 7:<<<getAllNonexistentParents in delayed deletion
' 0.008867 7:<<<findAppInfoNonexistentParents in delayed deletion
' 0.009992 6:<<delayed deletion
' 0.027111 5:<<ADocumentMerge::delayedPropagation
' 0.000394 6:<<<EndOrAbortUndoTransaction() -- trackers regen;DOPT;
' 0.000013 6:<<<EndOrAbortUndoTransaction()--AtomViewReferencingUpdate();DOPT;
' 0.000002 7:<<<EndOrAbortUndoTransaction()--end of transaction checks--invisible elements;DOPT;
' 6:< Connecting session [$43a85431] to Worksharing Log [C:\Users\tnorris\AppData\Local\Autodesk\Revit\Autodesk Revit 2014\Journals\journal.0067.txt]
' 0.000008 7:<<<WorksharingLog::getSlog []
' 6:< Additional IP address/name found for host TNorris-PC: 192.168.1.105
' 0.000011 8:<<<;PERF;MISC;regenerating
' 0.000855 6:<<EndOrAbortUndoTransaction()--end of transaction checks;DOPT;/ALL_GAPS 0.000835/TurnOff_GAPs 3%
' 5:< ::3:: Delta VM: Avail +22 -> 8384791 MB, Used -1 -> 420 MB; RAM: Avail -2 -> 57846 MB, Used -2 -> 479 MB
' 0.002006 6:<<<ElemTable::expandElementsInParallel
' 0.004364 5:<<EndOrAbortUndoTransaction();DOPT;/ALL_GAPS 0.001095/TurnOff_GAPs 1%
' 0.034564 4:<<delayed propagation on open
' 0.000008 4:<<<updating dependencies on open
' 0.000010 6:<<<EndOrAbortUndoTransaction() -- trackers regen;DOPT;
' 0.000001 6:<<<EndOrAbortUndoTransaction()--AtomViewReferencingUpdate();DOPT;
' 0.000001 7:<<<EndOrAbortUndoTransaction()--end of transaction checks--invisible elements;DOPT;
' 0.000002 8:<<<;PERF;MISC;regenerating
' 0.000064 6:<<EndOrAbortUndoTransaction()--end of transaction checks;DOPT;/ALL_GAPS 0.000061/TurnOff_GAPs 33%
' 0.000354 5:<<EndOrAbortUndoTransaction();DOPT;/ALL_GAPS 0.000279/TurnOff_GAPs 1%
' 0.000429 4:<<reloadLinkedInstances [0/0]
' 0.000003 5:<<<;PERF;MISC;regenerating
' 0.000003 5:<<<EndOrAbortUndoTransaction() -- trackers regen;DOPT;
' 0.000001 5:<<<EndOrAbortUndoTransaction()--AtomViewReferencingUpdate();DOPT;
' 0.000000 6:<<<EndOrAbortUndoTransaction()--end of transaction checks--invisible elements;DOPT;
' 0.000002 7:<<<;PERF;MISC;regenerating
' 0.000057 5:<<EndOrAbortUndoTransaction()--end of transaction checks;DOPT;/ALL_GAPS 0.000055/TurnOff_GAPs 33%
' 0.000189 4:<<EndOrAbortUndoTransaction();DOPT;/ALL_GAPS 0.000128/TurnOff_GAPs 3%
' 3:< ::3:: Delta VM: Avail -114 -> 8384678 MB, Used +120 -> 541 MB, Peak +121 -> 543 MB; RAM: Avail -223 -> 57623 MB, Used +122 -> 601 MB, Peak +120 -> 603 MB
' 3:< Unnecessary nesting;Document\PostLoadDocument.cpp;398;ID_SETTINGS_SNAPPING ;N++E(N);
' 1.141800!!!!! 4:!!!BIG_GAP [Cloud]postLoadDocument
' 0.000011 5:<<<EndOrAbortUndoTransaction() -- trackers regen;DOPT;
' 0.000001 6:<<<EndOrAbortUndoTransaction()--end of transaction checks--invisible elements;DOPT;
' 0.000005 7:<<<;PERF;MISC;regenerating
' 0.000080 5:<<EndOrAbortUndoTransaction()--end of transaction checks;DOPT;/ALL_GAPS 0.000074/TurnOff_GAPs 26%
' 0.000295 4:<<EndOrAbortUndoTransaction();DOPT;/ALL_GAPS 0.000201/TurnOff_GAPs 3%
' 0.049821 4:<<<pKeynoteTable->readFile
' 0.002542 5:<<;PERF;MISC;regenerating
' 0.000004 5:<<<EndOrAbortUndoTransaction() -- trackers regen;DOPT;
' 0.000362 5:<<EndOrAbortUndoTransaction()--end of transaction checks;DOPT;/ALL_GAPS 0.000359/TurnOff_GAPs 6%
' 0.000801 4:<<EndOrAbortUndoTransaction();DOPT;
' 3:< Document save history --> :
' 3:< Revit 2014 - Preview Pre-Release 2014 (2014.000) : 20130123_1540(x64)
' 3:< Revit 2014 2014 (2014.000) : 20130308_1515(x64)
' 3:< Document save history <--
' 1.235535 3:<<[Cloud]postLoadDocument
' 1.682772 2:<<DocumentStorage::onOpenDocument [E:\DH_City_Hall\Scene Exports and Revit Data\Denham Springs City Hall(Recovery).rvt]
'H 13-Mar-2017 09:46:40.049; 1:<
Jrn.Directive "DocSymbol" _
, "[Denham Springs City Hall(Recovery).rvt]"
'H 13-Mar-2017 09:46:40.080; 2:<
Jrn.Directive "GlobalToProj" _
, "[Denham Springs City Hall(Recovery).rvt]", "3D View: {3D}" _
, 0.01041666666667 _
, 0.70710678118655, -0.40824829046386, 0.57735026918963 _
, 0.70710678118655, 0.40824829046386, -0.57735026918963 _
, 0.00000000000000, 0.81649658092773, 0.57735026918963 _
, 1.66348241313665, -2.40212210117545, -827.87583404642908
Jrn.Directive "ProjToPage" _
, 1.00000000000000 _
, 1.00000000000000, 0.00000000000000, 0.00000000000000 _
, 0.00000000000000, 1.00000000000000, 0.00000000000000 _
, 0.00000000000000, 0.00000000000000, 1.00000000000000 _
, 0.00000000000000, 0.00000000000000, 0.00000000000000
Jrn.Directive "WindowSize" _
, 1575, 644
' 2:< Before : Create Display Manager
' 2:< System (MB) [Available / Total ] [Revit Memory Usage (MB) ]
' 2:< RAM Statistics: 57619 / 65458 603=InUse 603=Peak
' 2:< VM Statistics: 8384671 / 8388607 542=InUse 543=Peak
' 2:< Revit Graphics Information
' 2:< Current Mode : DirectX Hardware
' 2:< Use Hardware: ON
' 2:< Use Overlays : ON
' 2:< After : Create Display Manager
' 2:< ::3:: Delta VM: Avail -15 -> 8384663 MB, Used +4 -> 546 MB, Peak +2 -> 546 MB; RAM: Avail -12 -> 57612 MB, Used +6 -> 608 MB, Peak +5 -> 608 MB
'H 13-Mar-2017 09:46:40.129; 2:<
Jrn.Directive "ScreenResolution" _
, 381, 1080
, 819, 843
' 2:< ::3:: Delta VM: Avail -18 -> 8384646 MB, Used +5 -> 552 MB, Peak +5 -> 552 MB; RAM: Avail -5 -> 57607 MB, Used +8 -> 616 MB, Peak +8 -> 616 MB
'C 13-Mar-2017 09:46:40.188; 2:< Protein : Register Preview Factories
'C 13-Mar-2017 09:46:40.189; 2:< Protein : Initialize Renderer Module
'C 13-Mar-2017 09:46:40.189; 2:< Protein : Load the MR Renderer plug-in
' 2:< ::3:: Delta VM: Avail -27 -> 8384619 MB, Used +1 -> 554 MB, Peak +1 -> 554 MB; RAM: Avail -2 -> 57605 MB, Used +1 -> 618 MB, Peak +1 -> 618 MB
'C 13-Mar-2017 09:46:40.233; 2:< Protein : initialize RPC plug-ins
'C 13-Mar-2017 09:46:40.264; 2:< Protein : Open Protein content Libraries
' 2:< ::3:: Delta VM: Avail -9 -> 8384611 MB, Used +12 -> 566 MB, Peak +12 -> 566 MB; RAM: Avail -13 -> 57593 MB, Used +12 -> 631 MB, Peak +12 -> 631 MB
'C 13-Mar-2017 09:46:40.309; 2:< Protein : Load Library:
' 2:< C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\2014\assetlibrary_base.adsklib
'C 13-Mar-2017 09:46:40.310; 2:< Protein : Texture Path:
' 2:< C:/Program Files (x86)/Common Files/Autodesk Shared/Materials/Textures/
' 2:< Protein Build 4.0.32.600
' 2:< MSI Version 4.0.32.600
' 2:< Version Control DLL 4.0.0.0
' 2:< ::3:: Delta VM: Avail 8384611 MB, Used 566 MB; RAM: Avail +111 -> 57704 MB, Used +0 -> 632 MB, Peak +0 -> 632 MB
'C 13-Mar-2017 09:46:41.317; 2:< Protein: RPC Message
' 2:< This plugin is unable to acquire a license.
'Only demo content will be fully functional.
' 2:< ::3:: Delta VM: Avail 8384611 MB, Used 566 MB; RAM: Avail -27 -> 57678 MB, Used 632 MB
'C 13-Mar-2017 09:46:42.184; 2:< Protein : Notify Plugins to load the content on the asset library
'C 13-Mar-2017 09:46:42.184; 2:< Protein : Register the Protein RenderingAsset Manager
'H 13-Mar-2017 09:46:42.187; 2:<
, 802, 826
'H 13-Mar-2017 09:46:42.188; 2:<
, 401.00000000000000, -413.00000000000000, 0.00000000000000
' 2.138087!!!! 3:!!!BIG_GAP [Cloud]openOntoDesktop
' 6:< ::3:: Delta VM: Avail -48 -> 8384563 MB, Used +36 -> 602 MB, Peak +36 -> 602 MB; RAM: Avail -27 -> 57651 MB, Used +26 -> 659 MB, Peak +32 -> 664 MB
' 6:< DBG_INFO: NULL argument.: line 800 of Elem\RailingHostHelper.cpp.
'H 13-Mar-2017 09:46:42.267; 2:<
, 1920, 985
, 1899, 964
' 2:< Activate "[Denham Springs City Hall(Recovery).rvt]" , 3D View: {3D}
' 2:< View Open: Element expansion used 0.000000 seconds averaging 0.000000 seconds/hit for 0 hits.
' 2:< ::3:: Delta VM: Avail -1 -> 8384562 MB, Used +10 -> 612 MB, Peak +10 -> 612 MB; RAM: Avail -21 -> 57631 MB, Used +13 -> 672 MB, Peak +7 -> 672 MB
'H 13-Mar-2017 09:46:42.611; 2:<
, 1696, 889
'H 13-Mar-2017 09:46:42.612; 2:<
, 1675, 868
' 2:< DBG_INFO: Detected unfrozen change of selection.: line 571 of n:\build\2014_ship_x64_inst_20130308_1515\source\revit\revitui\modscope\ModScope.cpp.
' 2:< <<Begin build CT>>
'Command:
'Category: 0
'Bar list:
'Presenter list:
'Product: Unknown
'<<End build CT>>
' 2:< ::3:: Delta VM: Avail +7 -> 8384569 MB, Used +1 -> 614 MB, Peak +3 -> 615 MB; RAM: Avail +29 -> 57660 MB, Used +2 -> 675 MB, Peak +4 -> 677 MB
'H 13-Mar-2017 09:46:42.946; 2:<
, 1684, 889
, 1663, 868
'H 13-Mar-2017 09:46:42.958; 2:<
, "[Denham Springs City Hall(Recovery).rvt]", "Floor Plan: Site" _
, 0.00416666666667 _
, 1389, 572
'H 13-Mar-2017 09:46:42.960; 2:<
, 819, 843
'H 13-Mar-2017 09:46:42.961; 2:<
, 802, 826
'H 13-Mar-2017 09:46:42.962; 2:<
, 3884.88745322252000 _
, 3884.88745322252000, 0.00000000000000, 0.00000000000000 _
, 0.00000000000000, 3884.88745322252000, 0.00000000000000 _
, 0.00000000000000, 0.00000000000000, 3884.88745322252000 _
, -1181.68322945092200, -910.89841525902386, 0.00000000000000
' 6:< DBG_INFO: If bHandleEdgeInCutPlane is true, bUseVertexTol should also be true.: line 2303 of GeomXSec.cpp.
' 6:< DBG_INFO: m_stairsHeight is not up to date. Some regen dependency is missing.: line 1097 of Elem\SRC_StairsElement.cpp.
' 6:< DBG_INFO: Unexpected: More then one GeomStep of Type StairsSupportJoinEndGStep: line 676 of N:\build\2014_Ship_x64_Inst_20130308_1515\Source\Revit\RevitDB\Regen\GeomStepList.h.
' 6:< DBG_INFO: Cannot get Landing Path curves!: line 785 of Elem\SRC_StairsPathGRepGenerator.cpp.
' 2:< ::3:: Delta VM: Avail -13 -> 8384557 MB, Used +5 -> 619 MB, Peak +3 -> 619 MB; RAM: Avail -8 -> 57652 MB, Used +10 -> 685 MB, Peak +8 -> 685 MB
'H 13-Mar-2017 09:46:43.054; 2:<
, 823, 847
'H 13-Mar-2017 09:46:43.055; 2:<
, 802, 826
'H 13-Mar-2017 09:46:43.059; 2:<
, 1684, 889
'H 13-Mar-2017 09:46:43.060; 2:<
, 1663, 868
' 2:< Activate "[Denham Springs City Hall(Recovery).rvt]" , Floor Plan: Site
' 2:< View Open: Element expansion used 0.044753 seconds averaging 0.000068 seconds/hit for 661 hits.
' 3.020331 2:<<[Cloud]openOntoDesktop
' 1:< DBG_INFO: When constructing ElementRecord, elem 0 not found: line 24 of n:\build\2014_ship_x64_inst_20130308_1515\source\revit\revitdb\elemtable\ElementRecord.cpp.
' 1:< 0 ModelServerState "Created": Current server = "Not Queried", Model server = "", Model server state = "Not Applicable"
' 1:< RAM Statistics: 57650 / 65458 686=InUse 686=Peak
' 1:< VM Statistics: 8384557 / 8388607 619=InUse 620=Peak
' 1:< 000000001031A2D8 CompactMemoryManager Memory Statistics: 8 MB with 2 MB view
' 1:< 000000001031A2B0 CompactMemoryManager Memory Statistics: 8 MB with 4 MB view
' 1:< 000000001031A238 CompactMemoryManager Memory Statistics: 8 MB with 4 MB view
' 1:< 000000001031A260 CompactMemoryManager Memory Statistics: 8 MB with 2 MB view
' 1:< 000000001031A300 CompactMemoryManager Memory Statistics: 8 MB with 2 MB view
' 1:< 000000001031A210 CompactMemoryManager Memory Statistics: 8 MB with 4 MB view
' 1:< 000000001031A288 CompactMemoryManager Memory Statistics: 4 MB with 2 MB view
' 1:< 000000001031A328 CompactMemoryManager Memory Statistics: 2 MB with 2 MB view
' 1:< Element Expansion Statistics:
' 1:< 26% Opening Plans (4583142)
' 1:< 0% Opening RC Plans (0)
' 1:< 66% Opening 3d Views (11677154)
' 1:< 0% Opening Elevations and Sections (0)
' 1:< 0% In Regnerate (124)
' 1:< 0% In Autojoin (0)
' 1:< 0% In Overlap Checking (0)
' 1:< 0% Reviewing PostedWarnings (637)
' 1:< 8% Other (1471561)
' 1:< total bytes expanded: 17732618
' 1:< ;EES;26;0;66;0;0;0;0;0;8;
' 1:< 0 ModelServerState "Destroyed": Current server = "Not Queried", Model server = "", Model server state = "Not Applicable"
' 4.965802-- 1:<<[Cloud]standardOpenDocumentFile
'E 13-Mar-2017 09:46:43.311; 0:<
' [Jrn.File Input Information] COMMON.FILE_INPUT.FILE_TYPE: .rvt 07700480.000000
' 0:< ::4:: Delta VM: Avail +44 -> 8384602 MB, Used -11 -> 609 MB, Peak +0 -> 620 MB; RAM: Avail +6 -> 57659 MB, Used -10 -> 676 MB, Peak +0 -> 686 MB
'E 13-Mar-2017 09:46:43.339; 0:<
Jrn.Size 0 , 823 , 847
'H 13-Mar-2017 09:46:43.339; 0:<
, 823, 847
'E 13-Mar-2017 09:46:43.340; 0:<
Jrn.Size 0 , 824 , 848
'H 13-Mar-2017 09:46:43.340; 0:<
, 824, 848
Jrn.Size 0 , 803 , 827
, 803, 827
'E 13-Mar-2017 09:46:43.341; 0:<
'H 13-Mar-2017 09:46:43.341; 0:<
, 824, 848
, 823, 847
'E 13-Mar-2017 09:46:43.342; 0:<
Jrn.Size 0 , 802 , 826
'H 13-Mar-2017 09:46:43.342; 0:<
, 802, 826
'E 13-Mar-2017 09:46:43.370; 0:<
Jrn.Size 0 , 1685 , 890
'H 13-Mar-2017 09:46:43.370; 0:<
, 1685, 890
'E 13-Mar-2017 09:46:43.371; 0:<
Jrn.Size 0 , 1664 , 869
'H 13-Mar-2017 09:46:43.371; 0:<
, 1664, 869
'E 13-Mar-2017 09:46:43.372; 0:<
Jrn.Size 0 , 1684 , 889
'H 13-Mar-2017 09:46:43.372; 0:<
, 1684, 889
'E 13-Mar-2017 09:46:43.373; 0:<
Jrn.Size 0 , 1663 , 868
'H 13-Mar-2017 09:46:43.373; 0:<
, 1663, 868
' 0:< ::14:: Delta VM: Avail -356 -> 8384246 MB, Used +349 -> 958 MB, Peak +341 -> 961 MB; RAM: Avail -230 -> 57429 MB, Used +214 -> 890 MB, Peak +204 -> 890 MB
' 3.709566 1:<<<;PERF;MISC;drawing
' 0:< ::14:: Delta VM: Avail -32 -> 8384215 MB, Used +22 -> 981 MB, Peak +23 -> 985 MB; RAM: Avail -42 -> 57388 MB, Used +22 -> 913 MB, Peak +22 -> 913 MB
'C 13-Mar-2017 09:46:47.252; 0:< idle0_doc
'H 13-Mar-2017 09:46:47.252; 0:<
Jrn.Directive "AllowPressAndDrag" _
, 1
' 0:< ::14:: Delta VM: Avail -2 -> 8384213 MB, Used +10 -> 991 MB, Peak +6 -> 991 MB; RAM: Avail -16 -> 57373 MB, Used +10 -> 924 MB, Peak +10 -> 924 MB
' 0:< <<Begin build CT>>
'Command: ID_BUTTON_SELECT
'Category: 0
'Bar list:
' Dialog_Essentials_FilterSelectionNew
'Presenter list:
'Product: Revit
'<<End build CT>>
' 0:< ::14:: Delta VM: Avail -216 -> 8383998 MB, Used +215 -> 1206 MB, Peak +220 -> 1212 MB; RAM: Avail -206 -> 57168 MB, Used +171 -> 1096 MB, Peak +171 -> 1096 MB
' 0.188754 1:<<<;PERF;MISC;drawing
' 0:< ::14:: Delta VM: Avail +91 -> 8384090 MB, Used -91 -> 1116 MB, Peak +0 -> 1213 MB; RAM: Avail +176 -> 57344 MB, Used -87 -> 1010 MB, Peak +5 -> 1101 MB
'E 13-Mar-2017 09:47:03.164; 0:<
Jrn.MouseMove 0 , 516 , 402
Jrn.MButtonDown 16 , 516 , 402
' 0:< getPrioritizedActiveEditMgr() = 00000000082C2220 0000000071FDFE80 0000000011C7A180
' 0:< ::16:: Delta VM: Avail -193 -> 8383897 MB, Used +193 -> 1310 MB, Peak +102 -> 1315 MB; RAM: Avail -123 -> 57221 MB, Used +125 -> 1135 MB, Peak +34 -> 1135 MB
' 0.224271 1:<<<;PERF;MISC;drawing
'E 13-Mar-2017 09:47:03.466; 0:<
Jrn.MouseMove 16 , 516 , 403
'E 13-Mar-2017 09:47:03.469; 0:<
Jrn.Wheel 16 , -120 , 2674 , 545
' 0:< ::18:: Delta VM: Avail +31 -> 8383928 MB, Used -31 -> 1280 MB; RAM: Avail -19 -> 57202 MB, Used +3 -> 1138 MB, Peak +3 -> 1138 MB
'H 13-Mar-2017 09:47:03.521; 0:<
, 3378.16300280219180 _
, 3378.16300280219180, 0.00000000000000, 0.00000000000000 _
, 0.00000000000000, 3378.16300280219180, 0.00000000000000 _
, 0.00000000000000, 0.00000000000000, 3378.16300280219180 _
, -1181.68322945092200, -911.89841525902386, 0.00000000000000
, -960.24628647906343, -845.52036109480343, 0.00000000000000
' 0:< ::18:: Delta VM: Avail -85 -> 8383843 MB, Used +86 -> 1366 MB, Peak +56 -> 1371 MB; RAM: Avail -28 -> 57175 MB, Used +40 -> 1179 MB, Peak +40 -> 1179 MB
' 0.104496 1:<<<;PERF;MISC;drawing
'E 13-Mar-2017 09:47:03.627; 0:<
Jrn.MButtonUp 0 , 516 , 403
'H 13-Mar-2017 09:47:03.628; 0:<
Jrn.Data "ViewManipPanFlag" _
, 1
Jrn.Data "ViewManipZoomFlag" _
, 0
Jrn.Data "ViewManipRotateFlag" _
, 0
'E 13-Mar-2017 09:47:03.631; 0:<
Jrn.Wheel 0 , -120 , 2674 , 545
'H 13-Mar-2017 09:47:03.631; 0:<
, 2937.53304591494950 _
, 2937.53304591494950, 0.00000000000000, 0.00000000000000 _
, 0.00000000000000, 2937.53304591494950, 0.00000000000000 _
, 0.00000000000000, 0.00000000000000, 2937.53304591494950 _
'H 13-Mar-2017 09:47:03.632; 0:<
, -767.69242302527232, -787.80031399548136, 0.00000000000000
' 0:< ::20:: Delta VM: Avail -37 -> 8383807 MB, Used +29 -> 1395 MB, Peak +70 -> 1442 MB; RAM: Avail -133 -> 57042 MB, Used +93 -> 1272 MB, Peak +94 -> 1274 MB
' 0.187437 1:<<<;PERF;MISC;drawing
'E 13-Mar-2017 09:47:04.474; 0:<
Jrn.MouseMove 0 , 281 , 312
'E 13-Mar-2017 09:47:04.475; 0:<
Jrn.Wheel 0 , 120 , 2429 , 449
'H 13-Mar-2017 09:47:04.476; 0:<
, -923.49628647906343, -859.92036109480364, 0.00000000000000
' 0:< ::22:: Delta VM: Avail -62 -> 8383745 MB, Used +61 -> 1457 MB, Peak +33 -> 1475 MB; RAM: Avail -55 -> 56987 MB, Used +49 -> 1321 MB, Peak +47 -> 1321 MB
' 0.121645 1:<<<;PERF;MISC;drawing
'E 13-Mar-2017 09:47:04.719; 0:<
Jrn.MouseMove 0 , 362 , 305
Jrn.Wheel 0 , 120 , 2520 , 447
'H 13-Mar-2017 09:47:04.720; 0:<
, 3884.88745322252040 _
, 3884.88745322252040, 0.00000000000000, 0.00000000000000 _
, 0.00000000000000, 3884.88745322252040, 0.00000000000000 _
, 0.00000000000000, 0.00000000000000, 3884.88745322252040 _
, -1116.32072945092270, -943.15841525902408, 0.00000000000000
' 0:< ::24:: Delta VM: Avail +75 -> 8383821 MB, Used -75 -> 1383 MB, Peak +90 -> 1566 MB; RAM: Avail +88 -> 57076 MB, Used -50 -> 1272 MB, Peak +44 -> 1365 MB
'E 13-Mar-2017 09:47:05.322; 0:<
Jrn.MouseMove 0 , 370 , 204
'E 13-Mar-2017 09:47:05.323; 0:<
Jrn.MButtonDown 16 , 370 , 204
' 0:< getPrioritizedActiveEditMgr() = 00000000082C2220 0000000071FDFE80 000000007B9CEFD0
' 0:< ::26:: Delta VM: Avail -136 -> 8383686 MB, Used +124 -> 1507 MB; RAM: Avail -62 -> 57015 MB, Used +61 -> 1334 MB
'E 13-Mar-2017 09:47:05.753; 0:<
Jrn.MouseMove 16 , 746 , 334
Jrn.MButtonUp 0 , 746 , 334
' 0:< ::28:: Delta VM: Avail +71 -> 8383758 MB, Used -68 -> 1440 MB; RAM: Avail +55 -> 57070 MB, Used -60 -> 1274 MB
'H 13-Mar-2017 09:47:05.807; 0:<
, 1
, -740.32072945092227, -1073.15841525902400, 0.00000000000000
'H 13-Mar-2017 09:47:05.808; 0:<
, 0
, 0
' 0:< ::28:: Delta VM: Avail +36 -> 8383794 MB, Used -42 -> 1398 MB; RAM: Avail -19 -> 57052 MB, Used +6 -> 1280 MB
'E 13-Mar-2017 09:47:06.007; 0:<
Jrn.MouseMove 0 , 825 , 306
Jrn.Wheel 0 , -120 , 2983 , 448
'H 13-Mar-2017 09:47:06.007; 0:<
, 3378.16300280219140 _
, 3378.16300280219140, 0.00000000000000, 0.00000000000000 _
, 0.00000000000000, 3378.16300280219140, 0.00000000000000 _
, 0.00000000000000, 0.00000000000000, 3378.16300280219140 _
'H 13-Mar-2017 09:47:06.008; 0:<
, -536.14846039210670, -973.09427413828178, 0.00000000000000
' 0:< ::30:: Delta VM: Avail -80 -> 8383714 MB, Used +79 -> 1478 MB; RAM: Avail -18 -> 57035 MB, Used +16 -> 1297 MB
'E 13-Mar-2017 09:47:06.076; 0:<
Jrn.Wheel 0 , -720 , 2985 , 448
'H 13-Mar-2017 09:47:06.076; 0:<
, 1460.47308959883590 _
, 1460.47308959883590, 0.00000000000000, 0.00000000000000 _
, 0.00000000000000, 1460.47308959883590, 0.00000000000000 _
, 0.00000000000000, 0.00000000000000, 1460.47308959883590 _
, 237.67330324814168, -594.40326378456780, 0.00000000000000
' 0:< ::31:: Delta VM: Avail +19 -> 8383734 MB, Used -23 -> 1456 MB; RAM: Avail -40 -> 56995 MB, Used +36 -> 1333 MB, Peak +55 -> 1421 MB
' 0.122773 1:<<<;PERF;MISC;drawing
' 0:< ::31:: Delta VM: Avail -82 -> 8383653 MB, Used +78 -> 1535 MB; RAM: Avail -104 -> 56892 MB, Used +76 -> 1410 MB
' 0.170841 1:<<<;PERF;MISC;drawing
'E 13-Mar-2017 09:47:08.368; 0:<
Jrn.MouseMove 0 , 85 , 338
Jrn.LButtonDown 1 , 85 , 338
' 0:< getPrioritizedActiveEditMgr() = 00000000082C2200 0000000071FDFE80 0000000000000000
'H 13-Mar-2017 09:47:08.390; 0:<
Jrn.Data "Restricted Propagation" _
, 2, 757
'H 13-Mar-2017 09:47:08.394; 0:<
Jrn.Data "Selection action" _
, "REPLACE", _
"SEL RESULT: Stairs : Stair : 7"" max riser 11"" tread"
'Category: 1
'Bar list:
' Dialog_Revit_FamilyBar
' Dialog_Essentials_SketchEdit
'Presenter list:
' PP_Elements_Are_In_ModScope
'Product: Revit
' {1} spacer_shr
'Cache:
'<<End build CT>>
' 0:< ::35:: Delta VM: Avail -52 -> 8383601 MB, Used +47 -> 1582 MB, Peak +23 -> 1590 MB; RAM: Avail -25 -> 56867 MB, Used +28 -> 1438 MB, Peak +19 -> 1440 MB
' 0:< ::35:: Delta VM: Avail +83 -> 8383685 MB, Used -84 -> 1499 MB; RAM: Avail +124 -> 56991 MB, Used -72 -> 1367 MB
' 0:< ::37:: Delta VM: Avail 8383685 MB, Used +3 -> 1502 MB; RAM: Avail -8 -> 56984 MB, Used +10 -> 1377 MB
' 0:< Unnecessary nesting;SymbolAttribDlg_3;-1;IDS_MODIFY_TYPE_ATTRIB ;N++EB(NB);
Jrn.Grid "Control; Modal , Type Properties , IDD_SYMBOL_ATTRIB; IDC_SYMBOL_GRID" _
, "Selection" , ""
' 0:< ::41:: Delta VM: Avail +11 -> 8383696 MB, Used -9 -> 1493 MB; RAM: Avail -4 -> 56980 MB, Used +2 -> 1380 MB
' 0:< ::43:: Delta VM: Avail -2 -> 8383694 MB, Used +1 -> 1495 MB; RAM: Avail +28 -> 57008 MB, Used +3 -> 1384 MB
' 0:< DBG_WARN: The given value for actualTreadDepth must be greater than 0 and no more than 30000 feet.
'ApplicationException is being thrown on behalf of the function <void __cdecl StairsElement::setActualTreadDepth(double)>. Dump file: C:\Users\tnorris\AppData\Local\Autodesk\Revit\Autodesk Revit 2014\Journals\journal.0067.0001.dmp: line 595 of n:\build\2014_ship_x64_inst_20130308_1515\source\stairramp\stairrampdb\gensrc\SRC_StairsElement.gen.cpp.
' 2:< ;PERF;MISC;FullUpdateGraphicCacheUpdater::updateAll() DBView3d id=184267: 329 elements need cache update
' 2:< ;PERF;MISC;FullUpdateGraphicCacheUpdater::updateAll() DBViewPlan id=29237: 342 elements need cache update
' 2:< ;PERF;MISC;FullUpdateGraphicCacheUpdater::updateAll() DBViewProject id=3651: 567 elements need cache update
'Command:
'Category: 0
'Bar list:
'Presenter list:
'Product: Revit
'<<End build CT>>
' 0:< TaskDialog "A serious error has occurred. The current action has been cancelled. It is strongly recommended that you save your work in a new file before continuing.
' 0:< ::44:: Delta VM: Avail +2 -> 8383697 MB, Used +4 -> 1499 MB; RAM: Avail -139 -> 56870 MB, Used +11 -> 1395 MB
'H 13-Mar-2017 09:52:17.088; 0:<
Jrn.Data "TaskDialogResult" _
, "A serious error has occurred. The current action has been cancelled. It is strongly recommended that you save your work in a new file before continuing. " & vbLf & "" & vbLf & "Would you like to save a recovery file?", _
"No", "IDNO"
'E 13-Mar-2017 09:52:17.091; 0:<
' [Jrn.AutoConvertedMessageBox] Rvt.Attr.MessageId: IDS_ACTION_CANCELLED_DUE_TO_ERROR Rvt.Attr.MessageAnswer: IDNO
' 0:< ::45:: Delta VM: Avail -93 -> 8383605 MB, Used +93 -> 1593 MB, Peak +9 -> 1599 MB; RAM: Avail -94 -> 56776 MB, Used +92 -> 1487 MB, Peak +47 -> 1487 MB
' 0.249935 1:<<<;PERF;MISC;drawing
' 0:< <<Begin update dbar>>
'Command:
'Category: 0
'Bar list:
'Presenter list:
'Product: Revit
'[Disable:]Dialog_Essentials_SketchEdit
' {1} spacer_shr
'Cache:
'<<End update dbar>>
Nachricht 6 von 9
Matt__W
The first thing I noticed is that you don't have any updates installed. I would HIGHLY recommend starting with updating Revit.
https://knowledge.autodesk.com/support/revit-products/downloads?release=2014
Also, your graphics card isn't on the list of certified hardware. http://usa.autodesk.com/adsk/servlet/syscert?siteID=123112&id=18844534&results=1&stype=graphic&produ...
Not saying it won't work. Just may need to update the drivers for it.
Matt Wunch
Twitter | LinkedIn
Nachricht 7 von 9
Matt__W
Would it be possible for you to share the model? We can do this offline if you're not comfortable with posting it here.
Matt Wunch
Twitter | LinkedIn
Nachricht 8 von 9
Applying the updates worked perfectly. I greatly appreciate your help. I will have to stay on top of that from now on.
Nachricht 9 von 9
Matt__W
Awesome! I'm glad I could help!
Matt Wunch
Twitter | LinkedIn
