"Selection Box" always zoom to extents in Revit
18 ANTWORTEN 18
Nachricht 1 von 19
jps-johannes
2761 Aufrufe, 18 Antworten
Hi!
Is there a reason that the command "Selection Box" always zoom to extents?
I use this alot in my 3D-views just to focus on a wall and it's surroundings (instead of isolate). It's really anoying that the zoom changes I just want to set the section box with this command.
(I get that it does this way when I use the command from a plan view)
Title edited for clarity by @Viveka_CD
Tags (1)
18 ANTWORTEN 18
Nachricht 2 von 19
Alan.johnson1970
als Antwort auf: jps-johannes
I use this feature a lot and I think it works fine.
Can you post an image of what its doing, and one of what you expect it to do please.
AJ.
Nachricht 3 von 19
jps-johannes
als Antwort auf: Alan.johnson1970
Hi!
Tanks for quick reply :leicht_lächelndes_Gesicht:
I forgot to mention that this bug? is greater when I use scope boxes.
So when I use the selection box the command zooms to the extents of the scope box.
This is really annoying on large models with large scope boxes.
It's hard to show with pictures so just try to make a large scope box and try again.
Nachricht 4 von 19
Alan.johnson1970
Ah ok, Yes with a scope box it zooms tho the extents of the scope box.
You could try this
Select the scope box and in Properties - edit the Views Visible, set the override for the 3D view to Invisible
Then use Selection Box again. This works for me.
AJ.
Nachricht 5 von 19
jps-johannes
That works but is not a good solution.
I want to see my scope boxes to use it for selection box commands.
for example
I select a wall and use selection box, when I'm done editing this wall I select the scope box for the current part of the building I'm modeleing and again use selection box.
I guess a lot of users would like it to work this way.
Nachricht 6 von 19
Alan.johnson1970
I would say that is the answer to your first question.
"Is there a reason that the command "Selection Box" always zoom to extents?"
You want to use selection box and keep the scope box and having both will zoom to the extents of the scope box.
Not the answer you wanted.
Maybe someone else will come along with another solution, but I cant think of one.
AJ.
Nachricht 7 von 19
jps-johannes
Thank you for your time.
Maybe devlopers will see this post and make the zoom and pan not to change when using selection box in a 3D view.
Nachricht 8 von 19
Viveka_CD
Hi @jps-johannes
Can you share a screencast of what you are experiencing? I can pass this information to the dedicated resource.
Nachricht 9 von 19
jps-johannes
als Antwort auf: Viveka_CD
This is my first screencast so lets hope it works and describes the problem :leicht_lächelndes_Gesicht:
Nachricht 10 von 19
jps-johannes
Also I would like to be able to select an assembly and select the selection box command.
Nachricht 11 von 19
KJK_PriMaxCAD.nl
Go to Visibility/Graphics Ovverides>tab Annotation Categories and  uncheck "Scope Boxes"
Nachricht 12 von 19
nmarshall
als Antwort auf: KJK_PriMaxCAD.nl
I have the same issues and tried both the suggestions without any luck.  it is so time consuming to zoom in all the time.  Would love a solution to this.
Nachricht 13 von 19
RSomppi
What part are you struggling with?
The zoom extents when applying the selection box cannot be changed. If you have scope boxes visible, they will be included in the zoom extents even if they aren't selected.
Nachricht 14 von 19
nmarshall
I selected all scope boxes in the project and selected invisible for 3D views.  In my 3D view I have unselected scope boxes in the visibility graphics. (Both these methods were given as solutions above).  When I select an item (e.g. a pipe or a sprinkler) and then type 'BX' for selection box, it is still zoomed way out.
Nachricht 15 von 19
RobDraw
@nmarshall,
Try creating a new 3D view. The one you are using may be corrupt.
Rob
Nachricht 16 von 19
nmarshall
A new 3D view did not seem to improve it.
Nachricht 17 von 19
RobDraw
als Antwort auf: nmarshall
The only other thing I can think of is that there is something about the elements in your selection that is increasing the extents.
Share your model.
Rob
Nachricht 18 von 19
RDAOU
Obviously, no solution has been accepted on this post because clearly the OP stated that he wants to always keep the Scope Boxes visible throughout the workflow. That being said, "Working with selection boxes without having Scope boxes" as well as "Not being able to hide or override scope boxes" are not related to the main topic.
Most probably you would be more successful if you start your own post, start with looking into solving the visibility and graphics issues of the 3D and then finding the most convenient  to have either or both Scope Box/Selection Box + automatic Zoom to whichever Extent is more Convenient
Apart from the above, the best you can do to work simultaneously with Selection Boxes and scope boxes  as @jps-johannes was aiming to is to get yourself acquainted with
  1. Temporary View properties
  2. and Keyboard shortcuts to Apply/Restore Temporary View properties
Routine will then work as follows (at least at my end):
  • TT > BX to apply and Zoom in
  • TR > ZE to restore and Zoom out
Nachricht 19 von 19
dslWFTY6
This is more of a workaround than anything. But I downloaded the "Zoom to Selection" (linked below) extension to pretty much get around this issue. I do the section box keyboard shortcut, then immediately hit the Zoom to Selection keyboard shortcut (I made it ZX, and I made section XC, so it's pretty easy to type both of them.). This will automatically bring your section box into the elements you selected.
https://apps.autodesk.com/RVT/en/Detail/Index?id=440251165309056974&appLang=en&os=Win64
