" Repeat" and " Create Similar"?
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
ysautodesklover
810 Aufrufe, 3 Antworten
Hi Revit Experts and dedicated users!
I have been using Revit for 4 years and today I realized unused command for families.
What is the difference between " Repeat" and " Create Similar"?
It would be great if you clarify the difference for me!
Thanks in advance.
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: ysautodesklover
Repeat: repeat the last command
Create similar: create a similar element
The difference is more apparent when you, for example, use a Move or Copy command.
Nachricht 3 von 4
Copying VS Repeating Command.
Repeat would be similar to hitting the spacebar in AutoCAD.
Copy Elements with the Create Similar Tool
Nachricht 4 von 4
ysautodesklover
Ah!
As I used anther command, I got the meaning of "Repeat"!
Thanks!
