"Profile sketch is empty!"
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
ecastillowario
2092 Aufrufe, 5 Antworten
Hello when i try to set my doors i have an error, An error occurred in family "M_Door-Passage-Single-Flush" that cannot be automatically resolved.
Error Information:
help!
5 ANTWORTEN 5
Nachricht 2 von 6
jay_colcombe
als Antwort auf: ecastillowario
The error defines the issue here and if you close an empty profile sketch this is the warning, have you edited the family at any point?
Try reloading in the original from the Autodesk Web source if not and see if you can repeat.
Insert Tab > Load From Library > Load Autodesk Family
Jay Colcombe
Autodesk Certified Instructor
Nachricht 3 von 6
ecastillowario
als Antwort auf: jay_colcombe
yes i edited, and i also reloaded the family but im having same problem, is just in specifics spots of my architectural plans. and some other im able to do it.
Nachricht 4 von 6
ennujozlagam
try this door?
Nachricht 5 von 6
ecastillowario
als Antwort auf: ennujozlagam
it worked, Thank you!
Nachricht 6 von 6
JHROPE
other better option is to disable the "Masonry Frame" in the door properties
