"Pick Lines" tool not identifying some curves
gaitan94
gaitan94
Community Visitor
Community Visitor
I imported a dwg file I draw in rhino in order to model the floors of my project in Revit. but when I try to use the "pick Lines" tool to create the contour of the floor there are some curves that I cant pick and some that I can, someone knows why this happens and how too solve it?
Try TAB-Select on one line that you can select and see if it picks them all up at the same time.
constantin.stroescu
it doesn't work for splines....
In order to solve the problem :
  • in AutoCAD  select the splines and use command Flatten
  • save the file and open it again in Revit as a succession of small curves -you will can use now Pick Lines tool
Constantin Stroescu
andrea.grillo
What about people on Autocad LT?
We don't have the "Flatten" command.
How do we fix this?
