"Phase Filter" is grayed, how to un-gray it?
octavio2
octavio2
Revit 2024: In the Properties Dialog, under the Phasing subheading, the Phasing line is working with New Construction and Existing, and can be changed, but the line above which is the one with "Phase Filters", are grayed on all the plans and cannot be changed.  How to un- gray it?
Please advise
Thanks in advance.
curtisridenour
you probably have a view template applied to the view. turn off the view template or adjust it to have the proper phase. you can also uncheck phase filter within the view template if you want to vary different views by phase filter but continue to use the same view template.
stevenR5BPN
Community Visitor
Community Visitor
how do you do that
curtisridenour
handjonathan
Hi @octavio2
Thanks a lot for posting your question to the forums!   Has the solution suggested by @curtisridenour helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
