Dear all,
I have exactly two slabs composed of the following layers: 20 cm RC and 2 cm plaster.
I want to create "parts" from these floors. One of them (small one) creates the parts but the other (big one) does not create parts. The "Create Parts" button is inactive and greyed out.
I have the following error message:
Revit does not allow creating parts from certain elements. Parts will not be created from these elements.
What could be the reason for this?
Thank you.
Just from that snapshot it is hard to tell. I only difference I see is that you have modified/cut the 4 corners of the slab...if they are both of the same floor type there should be no other reason the following
See this article too "Can't make parts out of these Elements [...]" in Revit
