"Material: Image" Field
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
1249 Aufrufe, 2 Antworten
Hey Everyone,
Trying to figure out if the field "Material: Image" can be accessed within a material.  It looks like it can only be assigned via schedule  and isn't exposed within the material editor (does not exist under material identity, appearance, nor custom parameters). Has anyone had any success on identifying where this lives or if it is truly only accessible through a material takeoff schedule? Attached is an image of the field I am talking about.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Yes that field is only accessible via a material take-off schedule. On the plus side, it would be confusing if it were to be accessible via the material manager, especially for materials with texture / cut-out / bump map images.
Nachricht 3 von 3
als Antwort auf: ToanDN
Yeah that's what I thought, but thanks for the confirmation. It would be great if you could schedule the actual texture map as opposed to having to re-upload the image file to this parameter if you want to provide a visual reference for the material in a schedule. Autodesk goes as far as recommending you create another parameter to schedule images within a material takeoff rather than using this OOTB field: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
