"Layering" Section Cuts for only a selected Element?
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
466 Aufrufe, 6 Antworten
Cutting ONLY the floorCutting ONLY the floorCutting ONLY the roofCutting ONLY the roof
Anyone knows how can I do LAYERING cuts on ONLY 1 element instead of the entire model? Example like the above. With only a "Wavy" cut which is like layered, but on only the floor for the first example, and only the roof for the second example.
Because I realised the section box / section command cuts the ENTIRE model which Is not what I wanted. I need only a specific element/component (example, the wall or maybe the roof) to be cut, but in a "Wavy"-Layered manner like the above.
Please anyone knows? :enttäuschtes_Gesicht:
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Anonymous
Model-in-place voids are your best bet in this scenario. Or create the assembly as a family and have a visibility parameter to turn on/off your presentation model (wavy one) vs your working drawing model (complete assembly)
Nachricht 3 von 7
Thanks for the reply, but as a complete beginner, I have absolutely no idea what u had just said... :enttäuschtes_Gesicht:
Nachricht 4 von 7
In short, use Model in Place Components or create a Revit Family. You will be able to get the look you are going for. A course in Advanced Revit should do the trick :leicht_lächelndes_Gesicht:
Nachricht 5 von 7
Are they for presentation?  You can create Parts from a layered roof, Split the part to create the wavy portion of it, then hide the side you want to hide.
Annotation 2019-10-31 170534.pngAnnotation 2019-10-31 170659.pngAnnotation 2019-10-31 170512.png
Nachricht 6 von 7
als Antwort auf: ToanDN
Thank u so much. Exactly what I need :leicht_lächelndes_Gesicht:
Nachricht 7 von 7
@ToanDN Mr Nguyen strikes again! Thanks for the support on that one. Definitely makes sense if it is a one-off application. @Anonymous just as long as you dont have to do this for a curved or sloped roof/floor.
