"IF" formula with "False reslut" get value itseft
18 ANTWORTEN 18
GELÖST
Nachricht 1 von 19
Ar_vxv
1016 Aufrufe, 18 Antworten
Hi!
Same like title. I try write If formula with false result by Input value ( not by  prevalue specify).
Is this possible!? Or another approach
For Examle: IF (H.1<110, H.2, <input value>)
With H.1, H.2 : the lengths of the two vertical sides
thanks for any help
Tags (1)
18 ANTWORTEN 18
Nachricht 2 von 19
als Antwort auf: Ar_vxv
I'm not clear what the "input value" is. Is it a value that can be computed?
Nachricht 3 von 19
Ar_vxv
als Antwort auf: barthbradley
Hi!
if i don't use formula. I will have to enter smt in the value cell= <input value>
>>> IF H.1 not < 110, <False reslut> by my <input value>.
Nachricht 4 von 19
Still unclear. What is supposed to happen if the formula returns "input value"?  Nothing?  Or do you literally want the Parameter feild to read "Input Value".   If it's a Text Parameter it could.
Nachricht 5 von 19
Ar_vxv
when H.1 <= 110 . I use the value of H.2
When H.1 > 110. I want to enter numeric value in value cell
Looks like this is not possible in revit. So is there any other way in this case
Nachricht 6 von 19
You cannot have a parameter that for input value and also reacts to a formula.
You need to add Input Value parameter:
d.2_input
d.2 = if (H.1 <110 mm, d.1, d.2_input)
Nachricht 7 von 19
Look it; if H.1 is greater than 110, you are going to have to arrive at SOME value. Why can't that value already be computed and ready to use?
Nachricht 8 von 19
Ar_vxv
als Antwort auf: ToanDN
can you explain d.2_ input more specifically:
I cannot enter d.2_input for Revit to accept.
which one do you mean:
-d.2_input
-d.2_100
-100
Nachricht 9 von 19
-d.2_input
-d.2_100
-100
The formula: d.2 = if (H.1 <110 mm, d.1, d.2_input)
in plain English: if H.1 < 110 mm then use value of d.1 for d.2, if H.1 ≥ 110 mm then use value of d.2_input for d.2; for example if you enter the value for d.2_input = 200 mm then d.2 = 200 mm.
If you still don't get it, just share you family here.
Nachricht 10 von 19
Ar_vxv
Thanks for help
Nachricht 11 von 19
Nachricht 12 von 19
Ar_vxv
-Why can't that value already be computed and ready to use?:
Currently, it depends on Sweep's position in the project. I will Duplicate the profile section and change the H.1 value to match. Now I want to add a function when H.1 <=110 then H.1 takes the value of H.2.
-Your image: :grinsendes_Gesicht_mit_lächelnden_Augen:
Nachricht 13 von 19
Revit 2022 family is attached.  I don't have Revit 2020.
Nachricht 14 von 19
Ar_vxv
From that Formula i can understand. Many thanks!
Nachricht 15 von 19
HUH??? That helped?  That's exactly what I've been trying to tell you all along!
Nachricht 16 von 19
mhiserZFHXS
No its not. You had the if false result as a set value, not another parameter.
Nachricht 17 von 19
als Antwort auf: mhiserZFHXS
No, that not what I was saying. Read Message #7 again.  I asked: "Why can't that value already be computed and ready to use?"  Where do ready-to-use, computed values come from? Other Parameters - that's where.
Whatever.  Obviously, we had a failure to communicate.
Nachricht 18 von 19
Ar_vxv
@barthbradley
It's true! I should have seen such a basic thing. Pardon my ignorance.
Nachricht 19 von 19
@Ar_vxv wrote:
@barthbradley
There's nothing to pardon. We just had a failure to communicate. I'm glad you reached an "Aha" moment. :zwinkerndes_Gesicht:
