"How to" set up a custom setting for linked Revit files
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
emaynardZLZLK
302 Aufrufe, 5 Antworten
I am working on projects and every time I link an architect's Revit file, I have to go into the VG to adjust the settings.  What I would like to do is find a way to have a presetting to turn off and on certain VG options.
Is there a way to have a custom setting for the VG that I can use on all my projects for the linked Revit files?  I am mostly working in R20 and above.
5 ANTWORTEN 5
Nachricht 2 von 6
recep.eliacik
als Antwort auf: emaynardZLZLK
You can save your settings in the relevant view with View>View Template>Create Template from Current View and then import them to other projects.
Recep Eliaçık
Artı&Artı Teknoloji Hizmetleri/Civil Engineer
ACPACI
Nachricht 3 von 6
Are you reloading the Link via Manage Links dialog box?  Doesn't sound like it.
Nachricht 4 von 6
emaynardZLZLK
als Antwort auf: barthbradley
Reloading the the linked file is not the problem.  I think you're missing what I am trying to do.
I am trying to get setting that can go from project to project.  It takes up a good amount of time turning on and off the VG options for the linked Revit files.  This is something I have to do for several views.  If I can find a solution, it can save me and my company days (maybe more) in design time.
Nachricht 5 von 6
View Templates + Transfer Project Standards.
Nachricht 6 von 6
Only if the links are with the same names across all projects.  In such case, you can save their VG to view templates.
