When panning around a Wall Section view and clicking in and out of detail callouts on a page, Revit will pause inadvertently and "Generate Graphics" for the sheet that the details are on. I have heard it may be because of a generally slow model or a graphics card issue. Any idea on what may be causing this?
Can you check and see if you have CAD link into those detail? As well do you have other 3rd party plugin?
try to tick audit before opening the file and try to untick use hardware acceleration from options and install latest updates from autodesk and see if helps.
