"Failed to open Document" Revit 2021
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
haleri
2800 Aufrufe, 6 Antworten
I have been trying to detach a file and save to a flash drive.  After doing so, I could not open the detached file and received the "Failed to open document" error message.  In trying to figure out why that might be, I can no longer open the original file.  I wonder if I may have accidentally changed a file location setting?
Issue 1:  Cannot open detached file that was saved on different drive.
Issue 2:  Now cannot open original file.
Help!!
6 ANTWORTEN 6
Nachricht 2 von 7
hmunsell
als Antwort auf: haleri
What steps did you take to make the "Detached File"?
can you post the file for us to take a crack at it :leicht_lächelndes_Gesicht:
Howard Munsell
Nachricht 3 von 7
haleri
als Antwort auf: hmunsell
File>Open>Select file and Detach from Central>Open
File>Save As>Rename and relocate file>Save
File Size is too large to post
Nachricht 4 von 7
haleri
Nachricht 5 von 7
FWIW: No problem opening the file here.
Nachricht 6 von 7
hmunsell
als Antwort auf: barthbradley
same as @barthbradley ..... opened fine. i opened with Detached from Central checked, Audit also checked. once opened i purged all unused and saved. when i saved i also checked the Compact Central Model. it took the 195mg file down to 57mg.....
i noticed the default path in the Sync to Central was an "E:/" drive. i assume that is your flash drive path? are you sure your flash drive has plenty of free space?
Howard Munsell
Nachricht 7 von 7
haleri
Thank you for trying this out.  It was a file path/free space issue.
