"Construction-DefaultGBRENU.rte was saved in a later version of revit" error
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
r.itardnut
379 Aufrufe, 2 Antworten
I get the following error whilst trying to link an IFC file into 2021 (2021 = supposedly what the project is based on)
"The file Construction-DefaultGBRENU.rte was saved in a later version of revit and cannot be retrieved in this version"
I opened the IFC in 2023 and it opens fine.
I created an IFC, then tried linking that into my 2021 model. I get the same error.
Please help.
2 ANTWORTEN 2
Nachricht 2 von 3
L.Maas
als Antwort auf: r.itardnut
When revit is opening an IFC it is using a Revit Project template for that. I expect it takes the template from newer Revit version or ther is already a rvt file made in newer version.
Two things to try.
Try the following:
-Go to the folder containing the IFC file and chcek if there is laready a rvt file with thesame name as the ifc
(e.g "IFC project xxxx.ifc" and "IFC project xxxx.ifc.RVT")
-Move the "IFC project xxxx.ifc.RVT" to a differetn folder (for backup reasons)
-Try ling again
If that does not work then try this
-Create a new (empty) template as in screenshot
Choose metric or imperial depending on your needs.
-Save and name the template (e.g IFC import template.rte) and store it somewhere
Then
-Go to File > Open > IFC Options
-In the Default Template for IFC import browse to the template you just created
-In the folder with your IFC, check that there is no corresponding RVT file (See above)
-Try opening the IFC again.
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 3
r.itardnut
The 2nd option worked ! Great thanks!
