This thing has been happening for a while, on both Revit 2016 and 2017 versions.
Its all updated, and add-ins cleared.
Even all the posts regarding this error have been tried but no use.
Please help, it's urgent.
Thank you for your reply.
I have already uninstalled and reinstalled both versions several times, temp files are also cleared.
But no use.
Same thing happening again.
Thank you for the reply.
The thing didn't work still.
I just tried all the options.
sucks.!!
Hi @govinddev.r
Please look at the articles HERE and HERE for a resolution to this issue.
Let me know if any of the recommendations help resolve your issue, otherwise send us your recent journal and NFO file. Let me know if you have trouble locating these files.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Thank you, ma'am.
The software is fully updated, as well as option 2 is already done.
I've tried both of them.
No use.
Is that because I've'nt installed Revit 2018 version?
The Same thing is happening for both Revit 2016 as well as 2017 versions.
performed the items shown.
Still receive fatal error pop up.
Does anyone else have a solution?
Thank you
