"An unrecoverable error has occurred" error when saving after adding .txt file
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
619 Aufrufe, 2 Antworten
Hello!
I seem to be having a strange issue with multiple families I have created. I receive the "An unrecoverable error has occurred" error.
I usually have to create a text file that contains all the family type catalog, then it can be added to projects with ease.
Saving without the text file has no issues, but once the text file becomes associated with the .rfa, it gives that error. I am using the most up to date version of Revit 2017 for this.
I've attached the file in hopes someone can help me here...
Thank you!
Beschriftungen (3)
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Looks like you have a misplaced comma.
as-is:
,Width##length##inches,Depth##length##inches,Countertop Visibility##Other,##Countertop##Other##
corrected:
,Width##length##inches,Depth##length##inches,Countertop Visibility##Other##,Countertop##Other##
Nachricht 3 von 3
als Antwort auf: barthbradley
That definitely seemed to be the issue!
Thank you so much!
