Quiero hacer planos de mi familia de mobiliario
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
1349 Aufrufe, 3 Antworten
Hola, estoy realizando familias de mobiliario para cargar en mi proyecto, mi idea es generar planos ( documentacion) de esas familias para poder enviarselas al carpintero, pero en el template de mobiliarios no existe la opcion de crear planos.screenshot.jpg
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
Build it in the Project environment if you are want to produce CDs for it.  No different than building a house in Revit. We don't build a home in a Family and load it into a Project.  Nor do we produce CDs from within the Family environment.
Nachricht 3 von 4
als Antwort auf: barthbradley
So if i want to create leves of my family should i load them inside the
entire proyect?
For example i created a chair, y want a detail of it, y have to load it in
the proyect?
Nachricht 4 von 4
entire proyect?
the proyect?
If I understand correctly, you are wanting to create essentially "shop drawings" for furniture construction.  If this is correct, I would model all the components that make up the piece of furniture individually, and then assemble all these components together into the finished product in the Project.   Once assembled, you create what Views and Schedules are necessary to describe the construction, and then place them on Sheets.
