Questions about Dimensions and Revit turning some dimensions off in a view
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
tstaudigel
1209 Aufrufe, 5 Antworten
We have a client that is wanting us to put dimensions on there project, but in our elevations we have lines that determine graphics on the walls. They want us to dimension the graphics, but they don't want us to have the graphics and the dimensions for the graphics to show on the drawings. I was wondering if there was a way to create a subcategory under dimensions that I can assign the graphic dimensions to and turn them off with the visibility/graphics override. I currently have a working and print template file that turns on and off the graphics.
So I am wanting to turn the associated dimensions with the graphics off but keep all other dimensions on.
Is this even possible?
Working is Revit 2017.2
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: tstaudigel
Dimensions are View-Specific Elements. Why not just create and dimension client Views?
Nachricht 3 von 6
Duplicate the view and place the dimensions only in the view you want to show the dimensions.
Nachricht 4 von 6
bin
You can create a different type of dimension for the graphics. After you finish the dimensioning, select all and save selection, then control the visibility in the filter.
Nachricht 5 von 6
tstaudigel
als Antwort auf: bin
Thank you! I was trying to use the filter idea but didnt think i could do it with annotation items. Now i see that saving that selection allows me to control the selection. Thank a huge help! I didn't want to have to create duplicate views.
Nachricht 6 von 6
A Selection Filter?! Revit already has a Selection Filter to do this. A much better one. Just create a different Dimension Type for Client-Specific Dimensions and then use Select All in View +Hide in View to hide all the other Types.
BTW: You should Duplicate Views and Create Client Specific Views.  It less work and more manageable in the long run.
FWIW: In case you are unaware, A Selection Filter needs to be updated. In other words, new dimensions won't be automatically added to the set.  Also, a Selection Filter for View-Specific Elements will only apply to ONE specific View.  It won't work with all Views. So you would need to create  -- and keep updated -- a Selection Filter for every different Client View.
