Hi @Marcus.Isacsson
Sorry to hear that you are facing graphic glitches in Revit.
A few questions for you:
Which version of Revit are you using?
Is this dwg file a survey drawing? Did you explode the dwg?
Is your graphics card updated with latest driver from the manufacturers' website?
Some options to try:
- Try inserting the files with the 'center to center' option, with manually re-positioning and pin it. (click the option 'Correct Lines That Are Slightly Off Axis')
- If you still continue to face these glitches, try importing your dwg file as a 2D drafting element family
- Linking is preferred because it does not bring in any unwanted exploded objects which can get converted to Revit elements.
- Do a fresh clean up of your cad file (recommended before you link)
- Check for xrefs and bind them to the drawing, using the Insert option to prevent redundant layers.
- Run SETBYLAYER. This command removes any color, linetype, or lineweight overrides from objects.
- Run PURGE. This command removes any unused layers, linetypes, blocks, and styles.
- Freeze any layers you don’t need.
- Save the Cad file and try linking it again in Revit.
Best practices to follow when linking DWG files into Revit
Let us know if you were able to resolve the issue.
