Question marks problem
justinlahey1
justinlahey1
Hi, after doing a few searches I cant seem to find a solution for my particular problem. I'm exporting my sheets to PDF and I'm getting these question marks showing. They are showing up in all the elevation,section and 3d view pdf's but not in floor plan. I have been able to fix the 3d views by turning off the annotation category in visibility and graphics settings. The question marks aren't visible in the revit views they are only appearing on the pdf sheets after export. I've tried turning off all annotation category before exporting however they are still showing. Any advice would be great as I'm ready to submit my assessment to college but cant until I get rid of these question marks.Capture 1.JPGCapture.JPG
What PDF printer do you use?  Have you tried other ones?
justinlahey1
Thanks, I'm using Adobe DC Pro. It may have something to do with upgrading from Revit 2015 to 2018? maybe something hasn't carried over in the upgrade?. I will try using another pdf export program anyways. Thanks.
chrisplyler
Definitely looks like tags that aren't picking up a value. Draw a selection box around the area you know they are hiding, filter the resulting selection down to the tags only, and see what they are. Delete them if they aren't necessary.
