Question Marks on Labels in Title Block
3 ANTWORTEN 3
Nachricht 1 von 4
505 Aufrufe, 3 Antworten
I am new to Revit and I have a problem with replacing the question marks with text on my title block labels.
The catch is that I have already tried the steps of assigning the shared parameters to the project parameters, and have selected "Sheets", but they still won't show up and are not even editable.
I could be missing something crucial. Does anyone have any troubleshooting suggestions?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
Is the Title Block Label using the exact same Shared Parameter as the Project Parameter?
Nachricht 3 von 4
als Antwort auf: barthbradley
Yes, the title block labels were created with Shared Parameters in the
Title Block rfa file.
After I uploaded the title block in the project template file, I brought
the same shared parameters through Project Parameters.
When I select “Project Parameters” under the Manage tab, these shared
parameters show up in the box that says “Parameters available to elements
in this project:”.
See attached Title Block for your review. It is a custom Title Block so
Shared Parameters are being set up be us.
Nachricht 4 von 4
Did you mean to post a file?
