QUESTION: How to create a complex shaped curtain wall?
3 ANTWORTEN 3
Nachricht 1 von 4
DillOfThePickle99
343 Aufrufe, 3 Antworten
So essentially I am designing a rec center and what I need is a curved curtain wall. For the lower level since it just goes up to a perpendicular plane I just created a diagonal mass and did that but for the upper level I ALSO have a downward sloped roof that changes angles multiple times. I cant figure out how to create a sloped curtain wall for that upper level because of how complex it is. I have tried creating a mass and editing all the sides but its near impossible because of how exact it needs to be. I have pictures below if anyone has any ideas. Thanks!
Beschriftungen (1)
  • Help
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: DillOfThePickle99
I would go with creating a mass form and apply a curtain system by face.
Nachricht 3 von 4
DillOfThePickle99
als Antwort auf: ToanDN
Yeah I tried that and its not exact enough sadly. Like I can get it close but there are sections that are still messy. I wish you could attach them to the roof like what you can do with regular walls automatically...
Nachricht 4 von 4
EDIT: I think I figured it out. I realized there is a new "slanted" wall tool so if I use that it looks doable.
