Question about modify Topo surface?
4 ANTWORTEN 4
Nachricht 1 von 5
omar.amohamed
352 Aufrufe, 4 Antworten
How to cut the topo surface in the attached picture?
That is a circular tank that looks like a cone in elevation view.
I want to remove the topo surface that highlighted with a red mark only without removing what exists at bottom of the tank.
4 ANTWORTEN 4
Nachricht 2 von 5
kh_jea
als Antwort auf: omar.amohamed
Have you tried using Building Pad?
If you're trying to create a void in the topo, this isn't possible. Only vertical cuts created with a Building pad (or split toposurface).
Nachricht 3 von 5
omar.amohamed
als Antwort auf: kh_jea
Yeah, I am trying create a void in toposurface cause the pad only create vertical cut.
Could you explain how to achieve that by split toposurface?
Nachricht 4 von 5
kh_jea
You can split a toposurface, but you will never be able to create a "void" (like a tunnel) under a toposurface.
https://knowledge.autodesk.com/support/revit-lt/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Revi...
Nachricht 5 von 5
Looks like a Sloped Building Pad would do the trick.
