Quantity survey/ linear unit
12 ANTWORTEN 12
Nachricht 1 von 13
bechiri.2010
944 Aufrufe, 12 Antworten
In quantity schedule, I want to show the unit of some material as linear unit (lm), how can I do this ?
12 ANTWORTEN 12
Nachricht 2 von 13
als Antwort auf: bechiri.2010
What’s the math? Can’t you just write the formula to calculate linear meters by extrapolating values from other fields?  Or, am I misunderstanding the challenge?
Nachricht 3 von 13
What categories are you scheduling?
Nachricht 4 von 13
bechiri.2010
Thank you for replies
I generated shape of water stop band (or water bar )in generic model ( l used revolve tool) ,but l want to schedule this element by linear meter because it is band and volume quantity has no-meaning
Nachricht 5 von 13
It's primary school geometry.  Below is an example of a simple family.
r = radius of centerline of revolve
Angle = revolve angle
Length (shared parameter) = 2 * 3.1416 * r * Angle / 360
Nachricht 6 von 13
als Antwort auf: ToanDN
Wouldn't "3.1416" = "pi()"?
e.g.: 2 * pi() * r * Angle / 360
Revit school vs primary school.
Nachricht 7 von 13
bechiri.2010
Thank you ToanDN,
Maybe you misunderstood me, I am not looking for the formula of the arc length,
My question is how can I create a schedule that will let me get the quantity amount of linear meter for a particular family ( for ex: band of water stop ) ?
Nachricht 8 von 13
@bechiri.2010: Go with me here...do you have any fields your schedule that report values that you could use in a custom formula calculation? I believe that is the larger point that Toan is making. If you know the math, then you can write the formula. How do you compute it manually?
Nachricht 9 von 13
Seriously?
This is an example if a revolve family that you need to build if you need to report the length in a schedule. If you don't want to do the formula in the family, you have to do it in the schedule via calculated value field, which is fine. Either way, you still need the formula.
The waterband information only useful to filter the schedule.
@Anonymous ha I was primary schooled properly but self taught Revit school so I didn't know how to write pi. Thanks.
Nachricht 10 von 13
@ToanDN, that's why I keep Munkholm's cheat-sheet pinned above all my workstations...because I forget sometimes too! HA!
https://www.revitforum.org/tutorials-tips-tricks/1046-revit-formulas-everyday-usage.html
Nachricht 11 von 13
Barth,
I bookmarked the very same page and showed it in my signature. But for some reason I didn't think about looking at it last night.
Nachricht 12 von 13
Revit Forum is doing their annual fund drive now. Hint, hint. Smiley (zwinkernd)
Nachricht 13 von 13
@bechiri.2010
Below is an example where I use the family in a project and schedule them.
