Purlins on curved beams
14 ANTWORTEN 14
GELÖST
Nachricht 1 von 15
3227 Aufrufe, 14 Antworten
This is first attempt so far to draw purlins on curved beam and need some help
ref plane cant be curved so how can we set planes for purlins to follow curved path ?
14 ANTWORTEN 14
Nachricht 2 von 15
als Antwort auf: Anonymous
Curved grids?  Reference lines?
Nachricht 3 von 15
als Antwort auf: ToanDN
No Luck so Far
In my section view
no option for curved grids, neither I can pick line to draw curved grids
In my Work plane pallet on ribbon no option of drawing ref lines
Nachricht 4 von 15
Used face base family. It worked
Still not sure how I can use grids and ref lines to achieve this
Any input will greatly appreciated. Always good to know more than one way to achieve the desired results
Nachricht 5 von 15
chrisplyler
I've never tried this...but I'm curious what happens when you use the Beam System tool and select the curved beams as the supports?
Nachricht 6 von 15
@Anonymous
I realized now the beams are curved on elevation, not plan, so obviously curved grid lines don't work. Sorry.
Nachricht 7 von 15
See the screencast.  Is it what you want?
Nachricht 8 von 15
johk02
That loks good - but how do you make sure the mambers are perpendicular to the curved surface - like purlins have to be?
JH
Nachricht 9 von 15
als Antwort auf: johk02
Create one perpendicular to the curve and do a radial array.  Or draw radiating rays to align the purlins with.
Nachricht 10 von 15
Alfredo_Medina
If the curve is another kind of curve, not just one single arc with radius, then you can't use array. You need to use a divided path and a repetition. Something similar to this roof by Antoni Gaudi, built more than a hundred ago in Barcelona, Spain:
If you want to read the story, follow this link to my blog:
http://planta1.com/blog/antoni-gaudi-s-ingenious-curves-made-a-temporary-building-last-more-than-100...
Nachricht 11 von 15
als Antwort auf: Alfredo_Medina
Using adaptive families would be the easiest way if OP didn't need to stick with the Structural frame.  Hence the workaround.
p/s: By the way, the picture in your post shows all purlins perpendicular to the floor, not the curvature of the roof.
Nachricht 12 von 15
Alfredo_Medina
Yes, in that case the purlins were perpendicular to the top of the roof. That's how I saw them in the photographs of the building:
Nachricht 13 von 15
Oh I realized we were talking about different things.  You were talking about the layout of the purlins and I was talking about the plumbness of those.
Nachricht 14 von 15
johk02
Thanks for the replies.
To clarify my question: I meant the purlins to be perpendicular to the roof sheeting
JH
Nachricht 15 von 15
Yes that is also what my understanding.  If you don't have to use structural members then an adaptive family (not set to always vertical) can get what you want.  If you have to use structural members then you have to manually rotate them around their axis if the curvature is not an arc.
