A project I am working in is currently running so slow. Every time i load the materials or try to use the paint tool the whole program freezes for up to 10 minutes. I am trying to use the purge unused to prevent this but even when i click that the program freezes forever and I have to restart Revit.
Is there any other way to purge or something else that would have a similar effect in cleaning up my project file? I have already used the Audit function upon opening.
Just an update..
After waiting 38 minutes it finally opened. Revit said there was over 200,000 unused things that could be purged (I am guessing this is a colossal/unhead of amount?). I unchecked selected all so I could begin to manually sort through and not accidentally purge something I would need.
After sorting through everything I had around 600 things to purge, where on earth are the other 200k things that Revit was picking up? I am literally unable to work on my project because of how slow the program is running.
Purge....as well as Audit.
...did you by chance explode any CAD lately? That might explain the problem.
...you may need to "restore" to earlier state (e.g. use a backup).
Hi Brad,
I had not exploded any CAD that i know of.
Something I have been doing though is using "Transfer Project Standards" to import materials from my main project to new families I have been making. Once I finished making the family I have imported it into my project. I don't know if I could be doing something wrong here? But it would maybe make sense as to why there is such an abnormal number of unused items in my project?
