Publishing Revit app issue
Hi, I want to publish a revit app in autodesk app store. I have question about the .bundle folder containing the .dll file and add-in manifest. Can I upload the .bundle folder containing the class libraries .dll files and the main .dll file along with the add-in manifest? Because I have used Nuget Packages like Newtonsoft and when I run the add-in, it shows the error "could not find NewtonSoft.json" when there are no class libraries .dll files along with the main .dll and add-in manifest. But when I run the add-in along with class libraries .dll, it works fine. Any work around will be appreciated if the above is not possible.
what does the App do?
The app uses Rest Sharp and Fire Sharp services to GET and POST data and I am suing NewtonSoft.json to serialize and deserialize the data.
