When publishing to BIM 360, if you do not specify which views to publish, revit defaults to publishing every view in the model, correct? If you specify which views you want to publish, it will only publish those specific views with the model, so when you share a package and you link in the published model in the package from the consumed folder, and set the visibility to "by linked view" it only shows those views that were published to choose from, correct?
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
PS: Is there a follow up question to this one where you say there is a problem and something not working as expected or this is just a general knowledge question?
General knowledge question. I couldn't find anything online that could give me a specific explanation.
There is a BIM 360 forum if you have product specific questions and there should be also something in Autodesk Knowledge base on this topic I think...
but anyhow
there was you answer mark it to help others find it just in case it is not covered in the the Product Help section
