Pset_SpaceParking
3 ANTWORTEN 3
Nachricht 1 von 4
940 Aufrufe, 3 Antworten
Pset_SpaceParking
Hi!
In Revit 2017, I want to create an IFC file with a parking space.
Therefore I export the model to IFC.
1. How to create an IfcSpace?
           Rooms and mapping probably.
2. How to add Pset_SpaceParking to that space?
           http://www.buildingsmart-tech.org/ifc/IFC2x3/TC1/html/ifcproductextension/lexical/ifcspace.htm
           http://www.buildingsmart-tech.org/ifc/IFC2x3/TC1/html/psd/IfcProductExtension/Pset_SpaceParking.xml
Thanks!
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
@Anonymous wrote:
Hi!
Use Room.
When you export from Revit to IFC and link the IFC in a Revit file, it creates a .ifc.rvt file with the same name as the IFC file.  Open that file in Revit and add any parameters you need and classify them as IFC Parameters:
Thanks!
Nachricht 3 von 4
als Antwort auf: ToanDN
Thank you for answering the question.
However, it is still not working.
1. I create a new project. I use Room Seperator and Room to create rooms.
2. Then I export to IFC. I can see the line with IfcSpace in the IFC-file.
3. I create a new project and link to the IFC file. I close the new project.
4. I open the ifc.rvt file, but that seems to be empty.
So, when I open the ifc.rvt-file, I dont see the parking spaces like you.
Nachricht 4 von 4
When I exported from RVT to IFC, I clicked on Modify Setup from the Export dialog and check the options below:
There maybe other options but I am not too familiar with them and I haven't testes them all to be honest.  There is also another IFC Export Options down at the very bottom of the Export menu, you need to scroll down to see it, look into there as well see if you find anything useful.
Try different IFC versions as well.  I think the most common is 2.3.
