Property lines table
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
1020 Aufrufe, 9 Antworten
Is there a way of merging these two tables together? I need the name, the area and de length of the segments but i don't know how to do it.
9 ANTWORTEN 9
Nachricht 2 von 10
als Antwort auf: Anonymous
Edit the 1st table and add the Distancia field.
Nachricht 3 von 10
als Antwort auf: ToanDN
I wish it was that simple, the thing is that there isn't the Distancia(Length) field on the first table. Just to clarify wich table is wich, the first table (the one with Nome[name] and Area) is the "Linhas de Divisa" table (i think it is propety lines in english, sorry if i'm mistaken). And the second table (that contains de Distancia[Length] field) is the "Propriedades dos segmentos de Linha" (wich i guess would be "Property lines segments" in english).
What exactly i'm wanting to do is: I need a table that contains the name and area of each lot, as well the lenght of its sides.
I need one of these two outcomes:
1- A table that contains everything i said above or
2- A table that contains the lengths and at least the name of its host.
I don't mind having two separate tables. My main goal here is to associate the lengths with the lots name.
Sorry for this extense reply. I just wanted to clarify what i'm trying to do, since english is not my first language. Anotação 2020-02-02 203557.png
Nachricht 4 von 10
RDAOU
@Anonymous
You can do that using either of the following:
  1. do it manually by typing plot name in the comment
  2. Use Dynamo to set plot name to the comment or some instance parameter of your choice
  3. Use Group/Link Group
    • Create a model group of the property lines of each plot and name it PLOT A, PLOT B...etc
    • Link Groups and create new file by "group name"
    •  Create schedule from Linked property lines and it will look like below
Nachricht 5 von 10
als Antwort auf: RDAOU
Thanks for the info. I will look into further into that another time. Right now, it will be easier for me doing it manually as i don't have much time to do it. I guess i will delve into the Dynamo realm to acomplish this task more easily. Again, thanks for the information.
Nachricht 6 von 10
I've found a much easier solution.
Above is shown the property lines segments table. And i didn't know wich one is from each lot. Also, i wasn't able to click on each line to fill any of these fields. But this came to my mind: Tags!
I noticed that these tags select individual lines, so all i had to do was to follow the **** train cj edit the tag family and add a Legenda (i guess in english revit is "legend"?). I added the legenda and associated it with "Comentarios" (comments) field. This allowed me to type what i want and:
Bingo! See the L1 appearing on the "Comentarios" field?
Now i can identify each line the way i need it.
Nachricht 7 von 10
RDAOU
@Anonymous
That was option 1 mentioned above :leicht_lächelndes_Gesicht: "to type it manually in the comments field"
Glad you are happy with your solution
Nachricht 8 von 10
Yes, it is. Well, almost :strahlendes_Gesicht_mit_lächelnden_Augen:. The issue was that i could not click on the line and type the comment. The tag was a workaround
Nachricht 9 von 10
RDAOU
@Anonymous
Basically you do not need the Tag, when you select row in the schedule it will highlight the individual line
Nachricht 10 von 10
You are right, i changed the color of the selection to see it better. One issue tough is that i have overlapping porperty line and some of them doesn't show. Anyway, i think i'm good to go now. Many Thanks
