Property Line tag is rotated 180 degrees from desired angle
1 ANTWORT 1
Nachricht 1 von 2
micah
923 Aufrufe, 1 Antwort
Hello Revit masters,
I would like to know how to rotate property line tags that are facing backward, rotated 180 degrees. See the attached image for reference. I would like the blue-highlighted tag to face the same way the topo text is facing.
1 ANTWORT 1
Nachricht 2 von 2
RDAOU
als Antwort auf: micah
Hi @micah
It's an issue of a reading convention (Up Down Left Right)...and I do not believe Autodesk provided the Option to edit/select the convention for Tags (It is only open for Dimensions)
I never came across a situation and never noticed it before. I think we have it always aligned to the property line from the outside...But if it is a must, (Where I have no control over text anootations) I would probably duplicate the view with detailing > make the crop Region visible >> select it >>> rotate it 180 degrees and that would result something similar to the following. (This may effect other annotations though - but nothing which requires a special attention)
