Hi, Im Working with 2017 Revit, created a property line in site plan by entering distances and bearings, all loaded fine and i know there is a property line in there as it is listed in properties, but for the life of me i cannot get it to view. Tried adjusting settings, what am i missing here? Thanks for your help
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
If you look under "site" in the views visibility graphics settings, make sure that "property lines" are enabled
Thanks Alex, visibility is on for property lines, got me stumped. Once I set up co-ordinates I should be able to click on screen and place it, but this does not happen. I am a student Designer so still learning but this has stumped me!!
Yes its no problem drawing it.
Thought it may be something to do with a filter applied to property line as I saved co-ordinates, but not sure on that.
Can you share a file? Without that we are just guessing.
Is the view cropped and the property line outside the cropped region?
Hi @Anonymous
By default, property lines display only in the site plan.
The display of property lines is controlled by the Visibility/Graphics dialog for each view.
To display property lines in other plan views, open the Visibility/Graphics dialog. On the Model Categories tab, select Site. Expand Site, and select Property Lines.
See HERE on how to create property lines
See HERE on information of how to use the Edit Table tool \ to convert a sketched property line to a table-based one.
If you do not see the Property Lines in the view, try toggling reveal Hidden Elements to see if they have been hidden.
Let us know if you were able to resolve your issue.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Hi viveka
when i print the sheet it appears ,and if i change the discipline to coordination the property line become visible, but if i keep it on Mechanical it won't show up.
i couldn't find the reason for that, could you help please.
kind Regards.
