Property line for each levels
6 ANTWORTEN 6
Nachricht 1 von 7
PrawiraV
529 Aufrufe, 6 Antworten
Currently I have a 4 storey projects.
It has different lease line for each level because it is located inside a shopping mall, and I need to display the lease line in every plans (there are about 20 plans in total).
I tried to use model line and assign it to each level, but I need the line to be in front
I used to do it with property line, but since each level has different boundary I end up having to hide it manually.
Is there any other way to do this?
Beschriftungen (2)
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: PrawiraV
You can use grid lines or match lines and set a limit to their vertical extent.
Nachricht 3 von 7
What about Plan Regions drawn around those Property Lines? You can clipboard copy-paste align to Views a Plan Region.
Nachricht 4 von 7
Actually, I misunderstood. What about adding the PLs to a Selection Set Filters and assign those Filters to Views/View Template?
Nachricht 5 von 7
PrawiraV
als Antwort auf: barthbradley
In that case I would need to have view template based on level but my current setting is to have view template based on the plan type. So for example like all ceiling plan view template, and flooring plan view template.
Nachricht 6 von 7
PrawiraV
als Antwort auf: ToanDN
I have match line and grid line too on the drawing, and they have to be display at certain way.
Nachricht 7 von 7
Override their graphics using view filters to your liking.
