Property Line Edit
8 ANTWORTEN 8
Nachricht 1 von 9
LanggamanXavierMassed
1910 Aufrufe, 8 Antworten
Property Line Edit
I tried to edit property line in visibility graphics, weight 6 and still can't see changes on the modelling area
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: LanggamanXavierMassed
Just curious if you had drawn property line or not!! coz it is not showing using visibility setting. Can you please upload an image so we all can get where we are lagging....
I have attached my file with increased line weight of property line with dot dash line style.
Akash
Nachricht 3 von 9
als Antwort auf: Anonymous
here it is sir
Nachricht 4 von 9
Which Revit version you are using? I am unable to load the project as I have Revit 2017 latest in my system.
Can you please send me another file with lower version.
Akash
Nachricht 5 von 9
you need to type TL to see the changes or select TL icon (Thin lines). thanks
Nachricht 6 von 9
here sir, but still no change
Nachricht 7 von 9
select your property line > right click > overrides graphic in view > by element > projection lines > weight > change to 6 > type TL. thanks
Nachricht 8 von 9
select your property line > right click > overrides graphic in view > by element > projection lines > weight > change to 6 > type TL. you can also change the colour or type of lines. thanks
Nachricht 9 von 9
try to change it from object style.
