Property Line colour
3 ANTWORTEN 3
Nachricht 1 von 4
noconnorG728Y
1868 Aufrufe, 3 Antworten
Hello ladies and gents,
We have an issues with property line.  It is set up at red at the line style with weight of 6. On some plans it is showing up pink and on some plans it is red. There is no halftone or overrides on the property lines set up. We are really sumped and was hoping some of you can help us.
Thank in advance
NiallOC
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: noconnorG728Y
Check VG of the view see if the category is overridden and the view filter as well.
Nachricht 3 von 4
_Vijay
also, check element override or not. then verify line type and object style
Nachricht 4 von 4
dtiemeyer
als Antwort auf: _Vijay
I know if the View Category is MEP, some Architectural items will be forcibly half-toned with no way to disable it. Try changing the View Category to either Arch or Coordination (and leave all other settings alone), this will tell you if you've found one of those special conditions.
My other CAD is a Cadillac and I like to Revit to the Max!
