Property line bearings - Tag displays 7 decimals for seconds.
2 ANTWORTEN 2
Nachricht 1 von 3
vghozlan
114 Aufrufe, 2 Antworten
Hi All,
I'm currently working on a project I haven't set myself. We got the file from another practice.
When I tag the property lines to verify that they are set properly, the tag displays 7 decimals to the seconds".
. The issue doesn't come from the tag, we've been using it on all our projects and never had an issue.
. The property lines were entered with the table. For instance, the table shows a bearing of 256° 06' 40", and once tagged, it shows 256° 06' 39.7675992" ...
. I've checked project units on the project file and the tag family, and nothing out of the ordinary (same settings as our company files working fine)
. I went to site settings (through massing and site), and it's set as our standard as well.
. The boundary lines are not closed. This may be (often is) inaccurate rounding of bearings in the survey but in this case it is inaccurate by 150mm which is not neglectable.
My gut feeling is that the issue comes from the 'bearing' parameter, associated with property lines, but I can't find a way to check how it's set anywhere. I've been looking online and had no luck, asked a senior Revit colleague and he never saw this.
Any leads are appreciated!
Beschriftungen (3)
2 ANTWORTEN 2
Nachricht 2 von 3
RDAOU
als Antwort auf: vghozlan
@vghozlan
Normally it should not use decimals for minutes and seconds. The option is not even there to set. If you switch the angle display to Degrees from N/S what do you get as a result?
How far from the internal origin are you working or if you have a dwg linked in it might have elements to far off from the internal origin ...(if you do not know, you would need to research topic and how it relates to similar minor inaccuracies
Nachricht 3 von 3
vghozlan
als Antwort auf: RDAOU
Indeed, the model is placed ~580m from the internal origin... but not only that, I found out that the file was originally an IFC that was open in Revit and used as a background to remodel, meaning the file got a bunch of undesired stuff from that IFC such as extra levels that are not in use (I need to reassociate model elements and delete these levels) and more.
I'm quite on a tough spot now. Ideally, i'd want to re-do everything from our template, but we don't have the fees for that since I'd need to re-do all views/sheets.
