property bar items
5 ANTWORTEN 5
Nachricht 1 von 6
453 Aufrufe, 5 Antworten
property bar items
Bom Dia
Preciso alterar o tipo de um elemento, no entanto, a guia de propriedades não está sendo exibida, você pode me ajudar?
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
What kind of element are you refering to?
Try and right-click on the element, where you can choose Properties to see the elements properties.
Nachricht 3 von 6
Change Family TYPES in PROJECT environment:
Add New or Edit Existing TYPES in FAMILY Environment:
Nachricht 4 von 6
I have an air conditioning unit, and when it is generic, you want to switch
to mechanical, and the option to change the type is not displayed on my
taskbar
[image: revit.PNG]
Nachricht 5 von 6
Sounds like you saying that you want to change the Category (not Type) of a Family INSTANCE in the Project.  You cannot.  But you could Save the Family to a New Name -- Change the Category -- Load into Project  --- and use both Families/Categories in the Project.
Am I reading you correctly?
Nachricht 6 von 6
Mirko.Jurcevic
Are you sure your Properties window is not on another screen? (That is turned off maybe, or, if it's a laptop, maybe the lid is closed)
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
