Properties and Project Browser Graphics Problem
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
3906 Aufrufe, 7 Antworten
Currently having an issue with the Properties Palette and Project Browser Palette. I have tried docking/undocking and also turning on/off under the View Tab > Windows > User Interface, but this glitch still seems to occur when dragging the windows. Wondering if this is a graphics card issue or maybe Revit needs to be reinstalled?
04_Project Browser Edited.PNG05_Project Browser Edited.PNG06_Project Browser Edited.PNG
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: Anonymous
Toggle Interface's Hardware Acceleration On/Off and see what happens (not to be confused with program's Hardware Acceleration).
Nachricht 3 von 8
als Antwort auf: ToanDN
I'm having the same problem, and toggling hardware acceleration didn't work for me unfortunately. I'm working from home via VPN, so my setup is different than usual. I'll keep troubleshooting.
Thanks!
Nachricht 4 von 8
Viveka_CD
Hi @Anonymous and @Anonymous
Are you having a multi-monitor setup?
Please see this article for more information. (Users reported that since the Windows 10x64 Fall creator update (build 1709) was installed, Revit dialog boxes leave trails when moved across the screen)
Let me know if this helps.
Nachricht 5 von 8
BIMologist_
Well the April 2018 update fixed my issue with 2017 and 2018. however on another computer it jacked up the palettes. they were blank or shown partial. I turn on the Aceleration for interface and it fixed the blank project browser and properties, however the trailing has not been fixed. I checked that the machine is set to High Performance in Power settings.
BIMologist / Dr. Revit
Approved Autodesk Services Marketplace provider - BIM Consulting
If you find this reply helpful, please use the Accept Solution or Like button below
Nachricht 6 von 8
Viveka_CD
Hi @Anonymous
I have not heard back from you in a while. Let me know if you need additional information.
You are welcome to unmark the solution and continue the conversation if you'd prefer.
Nachricht 7 von 8
als Antwort auf: Viveka_CD
Hello Revit forum,
It doesn't sound like the problem has been fixed, (R18)
I have the same problem here, worked perfectly for some time, but started having this trouble recently.Capture.PNG
Hope you guys have some some troubleshot about it.
G.
Nachricht 8 von 8
Maybe, this situation depend of the file I open, Sometime there is no problem.
