Project Template File Locations not saving in Options
3 ANTWORTEN 3
Nachricht 1 von 4
mpukas
141 Aufrufe, 3 Antworten
When I add the location of my template to Options>File Locations>Project Templates, the location is never saved. Is there a way to save?
Tags (1)
3 ANTWORTEN 3
Nachricht 2 von 4
azad.Nanva
als Antwort auf: mpukas
Yes , it save.I don't see any problem.
Nachricht 3 von 4
Simon_Weel
Those settings are saved to revit.ini which you can find in the Windows User profile folder C:\Users\<username>\AppData\Roaming\Autodesk\Revit\Autodesk Revit <version>
Check if the file exists and if it's writable. Maybe it's flagged read-only?
Nachricht 4 von 4
SteveKStafford
Is it possible that your office IT office overwrites the Revit.ini file each day or prevents users from changing the file?
Steve Stafford
